Structural Insulated Panels (SIP) can create a strong, well-insulated, airtight, building envelope. They can, however, be unforgiving when it comes to moisture management. Most SIP dry slowly if or when they get wet, so back-vented claddings, robust flashing details, meticulous sealing of penetrations, and effective spot/whole house ventilation are all essential.
Detail Caption:
Joist hangers are attached to multiple joists just as they are attached to panel top plates. Follow panel manufacturer plans carefully for joist hanger specifications. Make sure multiple joists are laminated together as per manufacturer's recommendations.
For more information on SIPs, see the Green Building Encyclopedia
For more information on SIP manufacturers
NOTE:The GBA SIP details consist of 90 pdfs. Currently, the details are not available as dwg files. These 90 details are copyrighted by Green Mountain Panel and included in the GBA Construction Detail Library with express permission from Green Mountain Panel. All of the SIP Details were drawn by Steve Baczek and reviewed by Peter Yost for Green Mountain Panel, the same team that developed all of the other GBA details.
To see the SIP details with the step-by-step installation procedures, download theGreen Mountain Panel Installation Manual.
