Structural Insulated Panels (SIP) can create a strong, well-insulated, airtight, building envelope. They can, however, be unforgiving when it comes to moisture management. Most SIP dry slowly if or when they get wet, so back-vented claddings, robust flashing details, meticulous sealing of penetrations, and effective spot/whole house ventilation are all essential.
Detail Caption:
By running wires in the space created by the held-up drywall, long horizontal lengths of wire can usually be run quite easily. This technique is a good choice on upper floors. On the first floor, horizontal runs can more easily be carried in the basement.
For more information on SIPs, see the Green Building Encyclopedia
For more information on SIP manufacturers
NOTE:The GBA SIP details consist of 90 pdfs. Currently, the details are not available as dwg files. These 90 details are copyrighted by Green Mountain Panel and included in the GBA Construction Detail Library with express permission from Green Mountain Panel. All of the SIP Details were drawn by Steve Baczek and reviewed by Peter Yost for Green Mountain Panel, the same team that developed all of the other GBA details.
To see the SIP details with the step-by-step installation procedures, download theGreen Mountain Panel Installation Manual.
