Detail Library
Unvented Roof for Hot Climate (Raised Heel Truss, Blown-In Insulation). Asphalt Roofing; Two-Coat Stucco Siding Over Rigid Foam
Roofs and walls need to dry
Unvented roofs can perform wellas long as they are properly detailed to limit moisture transfer from the interior. Construction details vary depending on climate, but closed-cell spray polyurethane foam (specifically allowed by Section R806.4 of the International Residential Code) can be used anywhere.
Enclosure overview
Exterior walls
Start Free Trial
Related
Community
Recent Questions and Replies
