Detail Library
Asphalt roof // unvented // cathedral // exterior 3″ rigid insulation
Roofs and walls need to dry
Exterior insulation keeps the framing warm and dry
By moving the insulation outside the framing, the chances of condensation are almost eliminated. Another benefit is that you can get a superinsulated roof without increasing the size of the rafters, or furring the framing down and encroaching on the living space.
For detailed information on this topic,读_Unvented Roof Systems_at BuildingScience.com
Unvented roofs can perform wellas long as they are properly detailed to limit moisture transfer from the interior. Construction details vary depending on climate, but closed-cell spray polyurethane foam (specifically allowed by Section R806.4 of the International Residential Code) can be used anywhere.
Venting above the sheathing allows drying
Conditioned attics with unvented roofs can still provide a drying path through ventilation. You can ventilate the roof cladding above the roof sheathing. You can do this the same way you ventilate wall claddings either with a drainage mat or with furring strips positioned above…
Start Free Trial
Related
Community
Recent Questions and Replies
