外面,完全隔离,阳台柱结构
在外面,完全隔离,必须在灰泥和使用钢螺柱建造的阳台柱结构,如果我们能够完全密封来自元素的内部,可以在其中的任何水分损坏在4C区域中,将灰泥施加到丙烯酸面板中以制作独立柱。
This is a renovation. The column is completely isolated from the dwelling. It must use a stucco finish (acrylic or not) (or something that looks like stucco). The idea of the acrylic or plexiglass panels is that they will never rot, they can structural, using steel studs (to help secure railings). The column is 10″ x 10″ x 7 feet. The stucco part is totally exposed to rain/wind.
Would we get any dew formation or mold in the inside of the air-tight column? What would you recommend the sheathing to be for it to never rot or rust, I suppose?
使用镀锌结构的某种底漆和防锈涂料(焦油,环氧树脂,......),以防止水分/锈,模具和二氧化硫损伤。铆钉将被浸入覆盖物中。优点是 - 效果 - 将不透水膜附接到墙壁组件的最脆弱部分之一。你的意见?
GBA详细资料库
由气候和房屋部件组织的一千个建筑细节的集合
彼得,
I don't think it's possible to create an airtight box as you propose. Nor do I think that an airtight box is necessarily desirable.
What you want to do is to choose durable materials that are unlikely to rot. Assemble the materials in such a way that that the assembly sheds water, but is able to dry readily. That means that vapor-permeable assemblies (cement backerboard or traditional Portland-cement-based stucco) are probably preferable to materials with acrylic additives that limit vapor permeance.
谢谢,马丁,回答我的问题!非常感激!我明白使用塑料板的想法有点奇怪,但塑料不会腐烂或锈蚀,所以它是一种吸引人的护套解决方案。但是,我同意你的看法,即使我们完全封印盒子,甚至没有任何水分的累积(因为没有人“生活在列内),里面仍然存在一些水蒸气当然,丙烯酸或有机玻璃的盒子没有腐烂,但模具可以在其中生长!不确定模具对亚克力面板做了什么损坏模具,如果有的话,但如果我们能够避免湿度,我们应该。所以,我应该和你同意。所以,我同意你的意见。通过面板和穿过灰泥(在结构顶部和/或底部的覆盖物边缘处的小塑料网格粘贴在覆盖物的边界处)从雨))覆盖有外部通风口(灰泥后置于固化后)?现在,关于网格上的灰泥拧到丙烯饼面板上。我应该使用什么网格?我不确定为什么有这么多类型。一世不会在灰泥上使用任何弹性体涂料,顺便提一下。右?但是透明的水基,透气的封口。对吗?
你有没有想过使用通风基地?制造的人可能不适合您的需求,但您可以制造或制作变种。
谢谢Malcom!哦!好主意!我会看看他们是否可以工作!
顺便说一句,我想启动/绘画或使用再保险sin galvanized steel studs (not sure how galv. steel studs likes resin) to delay to the maximum rust. I read that they have special primers and special anti-rust paint. Sulfur dioxide (acid rain) might be an issue, but not sure. If not, this should be good for a very long time. This will make the use of membranes useless or redundant. Time to coat the studs in a dip to dry method should be fast, but I hear that they need to cure if water-based painting is used. I doubt that the primers and paint would be water based. As an option, I have thought of using an epoxy-tar product, but I think a resin is more appealing as we are still discovering ancient insect in old sap which is is like a resin, I think. What do you think? I know this is not green, but if it does not need to go to the landfill, it is one way of doing it! :)
当然,我不确定使用丙烯酸或有机玻璃面板时如何施加到车床的斯特科。这应该是一个有趣的实验!有什么想法吗?我读到了从内部的灰泥治疗/干燥。
