社区and Q&A
Earth Tube used to moderate air source heat pump condenser operating temps
Timothy Vos|发布了General Questions在
长时间读者第一次发布。
Has anyone tried or thought of using an Earth Tube to pre-heat or cool the air for an outside condensor of an Air Source Heat Pump or Mini-split?
Earth tubes are new to me and not common in most of MN. I have read about the downfalls of these poorly designed or installed earth tube systems for indoor air quality. Radon is a considerable problem in MN and I see an earth tube system only adding to it.
我喜欢ASHP或迷你分机系统的效率,即使在最寒冷的日子里也能够提供热量。我的理解是,当我们低于0度的人时,我们或任何大的Deltat都是那么大的,系统并不像能够有效地产生热量。
Could the outside condensor be enclosed in a small, insulated, exterior space (similar to a porch or breeze-way) where a few 100′ runs of burried earth tube loop starting and ending with a small fan system to move air through the tubes?
Air from the Exterior, enclosed room that houses the condensor enters the tube is moved by the fan through the earth tubes to either warm it or cool it prior to re entering and being used by the ASHP condensor to make interior heat or cooling more efficient with lower DeltaT values theoretically.
Thoughts?
加入建设科学专家的领先社区
  1. Andy CD Zone 5 - NW Ohio||#1
    Hey Timothy, it's an interesting idea, but it has been covered here. Previously, the suggestion was doing something similar with a passive solar enclosure around the ASHP outside unit. But it moves a vast quantity of air across its coils; the fan is working hard. At this rate of airflow, an earth tube long enough to allow some heat exchange with the soil would have a very high static pressure; it would require ANOTHER large fan, with a current draw likely to negate any gains at the heat pump. And the soil surrounding the earth tube will very quickly cool so that it is no longer exchanging ANY heat. You're encroaching on the Rube Goldberg territory of geothermal heat pumps. I think ASHP's are already engineered to within a micron of their peak efficiency. As they always say here, spend the extra money on improving your home's envelope, or on solar PV.
  2. Paul Kuenn||#2
    You may want to ask about the massive earth tube investment the Aldo Leopold Foundation used at the headquarters many years back.https://www.aldoleopold.org/visit/the-leopold-center/
    I'm sure they have some interesting feedback.
  3. Expert Member
    Zephyr7||#3
    There are heat exchangers available to use heat from air conditioner refrigerant lines to heat swimming pools, a kinda-sorta “combined cycle” arrangement. You could probably use one of these heat exchangers and a small circulation pump to use water circulated under the ground to help your system efficiency. A water loop will be easier to install than one moving air, and will probably work better too.
    Bill
Recent Questions and Replies
