Insulation fabric
Other than thickness is there any difference between insulweb, insulguard, and polyweb. Insulweb has 1.5 tensile and poly web is at 1.2 tensile strength. Since I am doing a dry installation of cellulose in the walls would I be able to use a fabric which is thinner or should I use the more expensive thicker fabrics.
