GBA标志水平 Facebook LinkedIn 电子邮件 Pinterest 推特 Instagram. YouTube Icon 导航搜索图标 Main Search Icon Video Play Icon 加图标 Minus Icon Picture icon 汉堡图标 关闭图标 Sorted
社区and Q&A
这是可易于的,它可以是绿色的吗?
Keenershipp.|发布了计划审查在
I am working on putting together the initial design concept for a 2nd home we will build in Northern Michigan. We built our current home as a custom build, but this builder had an architect they worked with, so we were able to design to a specific cost as opposed to selecting what we want to build and figuring out if we can built to our budget. I am interested to get insight from this community into the plans I am leaning towards.
https://www.concepthome.com/house-plans/house-plan -ch524-house-plan/21/?fbclid=iwar1svrmcn5bq_voyukaaw8myn_r5ireweaqkjmhtkxorsuyyjgnj1e2d37g
我希望在以下社区的洞察中:
1. Does this look like more costly or economical home to construct and finish? We would build with a 4ft crawl space, and the land is flat. We are hoping to stay under $225/square foot for the finished home. We are not planning on super high end materials and finishes. This is where we are willing to compromise.
我们目前的想法是,我们将为刚刚过去的厨房开始为生活空间的内饰做成角度的屋顶。关于我们将其作为节能家庭建立这一目标的能力有何看法(计划肯定使用喷雾泡沫绝缘,合理的优质窗口等)。但是,我知道这些选择也会影响成本。
I am excited to get input from this community!
Holly
  1. Keenershipp.||#1
    添加更多信息...我们中有2个人。我们计划从这套计划想法(附加车库)的变化4。我们可以几乎以任何方式向房子定位,但计划有南方的生活区。我们计划3间卧室可容纳客人,并计划有一间卧室担任办公室。客人卧室向我们(10x13')看起来有点小,所以我们正在考虑将2位Feett添加到房子上,使这些房间更广泛。我们不打算户外壁炉。我们将计划更少的门并替换一些窗口。有关对计划的反馈帮助的任何其他问题?谢谢!
    1. Expert Member
      马尔科姆泰勒||#2
      Keenershipp,
      I don't see anything that is inherently expensive or hard to make energy efficient about the design - and nothing that would necessitate using any spray foam.
      Without getting too deep into any changes you might want to make, If this is a vacation home, I'd consider eliminating the formal entry and much of the hall. That space could then be incorporated into the larger dedroom you want without making the house any bigger.
      1. Keenershipp.||#7
        Thank you Malcolm for the feedback! I also do not love the long hallway from the front door. My husband really wants there to be some entry door beyond the garage and the door walls from the living area. He is also very set on the garage being attached.
        I am very interested in any floor plans suggestions you can offer for ways of making the entry more welcoming, shortening the hallways or potentially moving the entry door to some other location (but where is what I keep looking at??).
        Holly
  2. Expert Member
    阿科斯||#3
    设计有很多。简单的形状,简单的屋顶设计。我绝对喜欢被覆盖的露台地区,这是很多房子小姐的细节。
    您仍然需要观看能效细节,并确保它们是您设计的一部分。您希望将空气紧密的信封成为您的构建的一部分,并且由于低坡度屋顶,可能最好瞄准屋顶甲板上的外部刚性绝缘。爬行空间杆墙应绝缘,确保在爬行空间地板上有多个。所有HVAC内部条件空间和带有ERV / HRV的延长。没有详细信息,我看到必须具有SPF,喷雾泡沫增加成本,在构建的早期设计。
    这些MCM风格的房屋总是遭受了很多(昂贵的)屋顶问题,因此尽量不要在那里放任何细节。没有天窗,或烟囱,用屋顶套管上方的刚性绝缘层,而膜屋顶而不是火炬。这些将持久耐用。
    The overhang for a southern exposure seem undersized, or at least you need a 2nd set of shades above the first row of windows. You can run it through one of the on-line shading calculators like this:
    https://www.insol.co.nz/overhang-annual-analysis-shading-calculators
    您通常在10月底之前不想要太阳能增益。
    一个修改我将为布局施加到侧面。走进一个狭窄的长廊的低门口不是最受欢迎的。在没有侧面车库的布局上,使杂物室进入泥厅和入口更好。
    Detached garages with a breezeway are generally much better for IAQ but does add cost which is well worth it. Plus it also gives you the option of easily turning the garage into a secondary suite down the road.
    Most new construction around me is without any attic, cathedral ceiling are pretty much the norm. Generally I find it simpler to build but your local builder might not. I would try to have the entire house with a sloped ceiling. I have never gone into a room with high ceiling and said, "you know, this really could use lower ceilings".
    Since I'm in the city, a 10x13 bedroom is luxurious, so I can't see it being an issue for a guest bedroom.
  3. Keenershipp.||#4
    Thank you Malcolm and Akos for the feedback! I also do not love the long hallway from the front door. My husband really wants there to be some entry door beyond the garage and the door walls from the living area. He is also very set on the garage being attached.
    Holly
    1. Expert Member
      Michael Maines||#5
      我想你会发现杂物间成为家庭入口。也许只是让那个正式的入口?没有规则说,该条目需要尽可能靠近街道,特别是对于度假住宅。
      1. Keenershipp.||#6
        Hi Michael, I agree this is the entrance we will usually use. We are planning to do the variation where the garage is attached to the utility room. We were hoping for one more door that does not need to go through the garage. Thanks!
    2. Expert Member
      阿科斯||#8
      You can take version #4 plan, shift the garage up towards the bedroom but keep the roof starting point at the same stop. This extra roof now is an overhang, which gives you a covered entrance by the utility room/mudroom that you can now use as the main house entrance. Change the garage car doors to the right side or flip to the other side.
      This layout works well if the living room faces the street, more open and welcoming as you walk/drive up to the house, much better curb appeal.
