普遍存在纽约州的车间墙壁建筑(5A区/ 6A区)
克莱特埃德加三世|Posted in计划审查在
我将在一个月或两个月的24'x32'独立的车间打破地面。我喜欢Martin的文章“让你的墙壁和天花板的绝缘材料”足够,以至于我将持持续的技术试用这个研讨会。这是我的墙面细节。
它在级别的速度辐射落地。基础是浇筑的混凝土脚上的块墙。基础,墙壁和屋顶与XPS泡沫绝缘。墙壁是2×4螺柱墙,带有开放式螺柱托架。如果我发现我需要它,我总是可以在螺柱托架中添加绝缘层和干墙。它有一个桁架屋顶。外部饰面是乙烯基壁板和沥青瓦片。我在外部基础泡沫上使用“地面断路器”面板。我计划热交换呼吸机以获得新鲜空气。
We were going to use 1×4 furring, but we are having trouble finding it in longer lengths at a reasonable cost. We will likely go to 2×4 instead of 1×4.
Please let me know your thoughts on the design. Also, please let me know if the drawing helps you.
非常感谢,
- C.B. Edgar.
    C. B. Edgar,
    It looks like you have the right idea. My only comments concern insulation thickness.
    如果我猜到正确,您计划在墙壁上安装两层2英寸XPS。这为您的R-20墙壁提供了几乎没有满足气候区域的最低代码要求。
    这将是工作的,但更多会更好。
    看起来你计划一个R-30屋顶。这不会符合最低代码要求。在第5区,您需要R-38屋顶,在6区,您需要一个R-49屋顶。所以你需要炖你的屋顶泡沫。
  2. Torsten Hansen.||#2
    克莱特,
    看起来像一个很棒的项目。由于这是一个自由的车间而不是你家的一部分,因此代码要求马丁是不可能申请的。核实您的建筑部门。
  3. 克莱特埃德加三世||#3
    Thanks for the comments! How much insulation and where it should go? Yup, I have been thinking about it, and I guess I am going to think about it some more. The PGH has 10/20/40/60. Hmm.
    在绝缘中,我首先消除博士afts and prevent moisture/condensation/mold problems. The foam seemed a good way to go. But how much foam?
    我在基础上放了很多泡沫。毕竟,我正在加热基础。任何过去泡沫的热量都朝着地面迈出了,我根本不擅长。当然,地面比空气更温暖,但我相信它仍然很重要。
    基于Martin的更多绝缘的建议,我做了一些分析并肯定,我已经失去了我的大部分热量。我使用了水分面积除以R值的加热度日,每年的热量损失获得BTU。
    With the current design, I am losing 410kBTU through the walls and 180kBTU through the roof. The foundation and slab account for 115kBTU, and the windows and doors account for 170kBTU. A total of 880kBTUs per year.
    基线:R-20墙壁和R-30屋顶,热量损失为410(47%)和180(21%)。总计:880KBTU。
    如果我使用R-40墙壁和R-40屋顶,则热量损失进入205(33%)和137(22%)。总计:630KBTU。
    如果我使用R-40墙壁和R-60屋顶,则热量损失进入205(35%)和91(16%)。总计:580KBTU。
    So I can save a third in heating by doubling the insulation in my walls and ceiling. I need to think about that. Of course, as I add foam, the building gets bigger, and in New York where assessment is based on external building size, a bigger building means bigger taxes...
    当然,所有这些都忽略了完全的能源代码。正如Torsten所说,我可能会也可能不必担心这一点。我当然会检查检查员。
    非常感谢您的输入。我会告诉你我的建设者和我决定。
Community
