Please recommend an under deck ceiling and rain drainage system which is durable and attractive?
I have just completed an all seasons lake front home with a walk out basement leading to a patio below a 10 X 24 ft pressure treated deck with TREX like flooring, I would like to install a long range durable, attractive, rain drainage system as a ceiling under this deck so that the patio may be used during inclement weather. Would appreciate any recommendations.
We build an EPDM covered deck and add decking on sleepers when your desire is requested.
Building a home it makes sense to ask questions prior to building not after. Trex and others sell under deck drain systems, that is your choice now.
不幸的是,AJ是正确的。一旦甲板在所有解决方案上,所有解决方案都明显排名第二。
同意了。您还可以使用轻量级concrete tile loose laid on the EPDM. No maintenance finish, 10X better looking than Trex.
James, After years of frustration dealing with both wood and composite decks I've started using concrete on all of them, whether they use membranes or not. Even using regular pavers it only adds about 20 lbs per foot dead load, which seldom necessitates much beefing up of the structure. The tyranny of deck maintenance must end!
I used to work with these guys on product development, this system actually works:
http://timbertech.com/products/finishing-touches/dryspace-drainage-system/
so will 24' galvalume panels mounted on steel hangers and with at least 1/4 bubble fall. Be careful as most plastic wood composite decks need ventilation underneath to keep them from doing crazy things. The dryspace system was designed with composite decks in mind, but Galavalume option is quick and cheap.
Good luck.
我们在蒙大拿州有一家天沟公司。我们之所以设计自己的,是因为市场上的所有设计都缺乏一个设计组成部分,或者只是没有吸引力。他们都试图提出一个复杂的设计,以便可以拥有自己的利基市场和/或专利。我们的面板搁在整个排水沟上,这些面板安装在整个副膜周围。但是,为了确保每个接缝拐角不会泄漏,就需要非常复杂的天沟安装程序。许多人似乎无法在我们的地区得到这个。您可以在线查看我们的图片。stillwaterguttersandmore.com。有一个回到东部的人,根据您的位置有类似的产品。面板和甲板之间有足够的空间,以允许空气循环。
