社区与问答
空气密封和绝缘的成本-效益
大卫B|已上传一般的问题在
我和我的妻子在两年半前和这里的一些人聊天后在MA买了我们的第一套房子,从那时起我们有一个承包商来处理地下室。它的天花板上有松散的玻璃纤维棒,我们用坚硬的泡沫取代了裸露的混凝土墙,并喷洒泡沫覆盖托梁(我想这就是基础墙顶部与木材接触处的叫法)。地下室比较暖和,但也不是特别暖和,而且这是一项昂贵的工程。我妻子接下来想处理我们的卧室。这是一间经过装修的房子,在一个车库上面,冬天很冷,夏天很暖和。车库的天花板和FROG的地板之间有松散的玻璃纤维,这肯定可以用一些密集填充纤维素来改善,房间的膝盖墙可以使用喷雾泡沫或泡沫板+密集填充纤维素,阁楼甚至连想都不想。大约1600平方英尺。脚上的玻璃纤维松了,虽然屋顶建造得很好,但上面有暖通管道,建筑工人们没有密封任何东西。理想情况下,我们会取出玻璃纤维,用空气密封所有东西(我们知道它漏水,因为最靠近地板的绝缘材料非常脏),然后吹进新的纤维素。主卧室和阁楼都是很大的空间,对此我无能为力,但我收到的报价在我看来很疯狂。 One contractor with a good reputation quoted me just north of $35K to address all the components I mentioned above, and said it was probably two weeks of work. I can’t even find a second person who’ll do things the way I want – the spray foam guys want to spray everything everywhere as thick as I’ll let them, and the cellulose guys don’t want to airseal. MassSAVE came and did an audit when we moved in, the blower door test was good enough that they wouldn’t subsidize any of the work for us. The house isn’t super comfortable, though. Are there any options besides shelling out tens of thousands of dollars? My wife and I are professionals with young kids, and even just doing the math on how many bags of cellulose I’d need for the attic combined with how much the rental blower can shoot out put it at 18 hours of uninterrupted time for that one thing alone. I don’t have time for that. Should I just go up there myself and spend 30 minutes a day in a tyvek suit, moving insulation, airsealing with a can, and moving the insulation back? I’d really appreciate any advice you all can offer. Thank you! NOTE: For reference, more than one person has told me it’s ~$2,500 a day to get a cellulose truck at your house in my area.
  1. 尼克Defabrizio||# 1
    我将把它留给本网站上更有经验的人来讨论这些选项。有一点我很熟悉,那就是你卧室地板下面的车库天花板。一些地区的规定要求卧室下面的车库天花板安装双层5/8石膏板。这可以在你进行空气密封和重新绝缘的同时进行。减少两个空间之间的空气泄漏对健康和安全、能源效率和舒适度都是一件好事。我提出这个问题的唯一观点是,你应该考虑这个问题,以及你考虑拆除车库的天花板. ....
    我认识的一个家庭也有类似的问题....在他们的案例中,新增的完工房间似乎从未从主暖通空调系统获得足够的CFM空气来适当地加热和冷却大卧室。你可能会重新考虑暖通空调系统,看看是否可以选择一个更强大但更高效的系统。或者你可以考虑为这个房间增加一个高效的迷你分隔。这两种选择都不便宜,但可能符合大规模清洁能源计划的退税条件。
    1. 大卫B||#2
      嗨,尼克——我不会拆掉天花板,我会让承包商在每个隔间的石膏板上钻洞,然后用这种方法放入密集的纤维素。纤维素只是压缩现有的蝙蝠。他们完工后就会封好,再用墙泥填上。
    阿尔卑斯山脉||# 3
    3万5千美元听起来像是一个离开的价格,但这个人就是不想这么做。
    大多数主要的热舒适问题是由空气泄漏引起的,所以这是你首先需要解决的问题,在那里添加额外的绝缘材料不会造成伤害,但不会有多大帮助。
    我会把工作分成几个易于管理的部分,让承包商为每个部分投标。首先要把车库的天花板拉起来用泡沫喷雾把地板隔热。当防晒人员在那里的时候,让他们在你的阁楼上喷洒和密封管道、寄存器和灯(这意味着耙掉现有的绝缘材料,但不是一个巨大的工作)。
    如果你有膝盖的墙,你也要用防晒系数来密封你的地板托梁和墙的交点。如果你能做它从车库的风箱,这是伟大的,如果不能,你需要做它从阁楼一侧,这是没有乐趣的。
    完成防晒后,重新安装车库天花板。我会把天花板挂在弹性通道上,以减少楼上的噪音传递,再把马达和履带安装在橡胶隔离支架上。
    如果你得到体面的流量通过管道,这可能会解决大多数您的舒适问题,你只需要四个接头:
    -demo/rake绝缘拆除
    防晒系数
    干墙
    -重新安装车库门硬件
    1. 大卫B||# 5
      谢谢你周到的回复,Akos。你是说我拆除车库天花板,喷洒它,重新安装天花板会比在现有的组件中添加密集的包装纤维素更好吗?
        阿尔卑斯山脉||# 6
        一个好的密集包装确实能很好地密封东西。虽然不像SPF那么密闭性,但已经足够好了。
        我建议防晒的原因是,它听起来有很多复杂的形状,确保所有的角落和缝隙都是密集的适当包装和密封将是一个挑战。打开天花板后,你可以看到这些问题并直接处理它们,此外,你还可以让喷泡沫的家伙去修补阁楼上那些密集包装不起作用的可疑区域。
        一个不错的奖励是,你会得到一个更好的空气密封之间的车库和房子的其他部分,以及通常没有尝试空气密封以上的车库隔断墙和奖励房间地板托梁。
        我通常尽量避免防晒,我认为在这种情况下,它使绝缘和空气密封更容易。
        由于您的公用事业不是那么昂贵,较低的成本选项可能是像前面建议的那样对问题施加更多的压力。要么看看你是否能增加现有管道上的空气流量,要么安装一个专用的壁挂迷你分离器。
  3. 删除||# 4
    删除
  4. 大卫B||# 7
    我从不同的供应商那里收到了一些报价。我不知道该怎么处理这些数字,因为报价不能直接比较。
    供应商1 - 5000美元,只是为了移除阁楼上松动的玻璃纤维和蝙蝠。他们的想法是,这样做的话,我就会不通过三年前我家通过的鼓风机门测试(这是一个非常低的标准),然后MassSave项目就会补贴所有的空气密封和阁楼上的新纤维素。据我所知,这基本上是一种欺骗,而且在一段时间内,我在马萨诸塞州的阁楼在冬天会没有绝缘材料。
    供应商2 - 12.5万美元,用于拆除阁楼绝缘材料,向R-38喷洒阁楼的泡沫屋顶线,向R-28喷洒车库上方的卧室的泡沫膝墙和山墙末端,并使用一些可以直接用泡沫覆盖的专用材料挡住屋顶拱部
    供应商3 - $3,100在阁楼上添加5英寸的纤维素(无空气密封),在膝壁上添加2英寸的泡沫板,那里目前有木棒,但没有蒸汽/空气屏障,并在车库上方的天花板(卧室地板)密集包装。
    说实话,我不知道该怎么做。似乎与无泡沫的家伙处理空气密封的地方,有松散填充的玻璃纤维是非常昂贵的,这就是为什么他们不想做它-或粗略的。喷雾泡沫的价格比我预期的要低,但把阁楼变成有空调的空间让我担心潮湿问题。
    关于我该怎么做,还有什么高见吗?另一则新闻,我们将在缅因州的一块土地上关闭,你可以打赌,我会把那栋板房的一层超绝缘的房子密封起来。
      阿尔卑斯山脉||# 8
      松散填充蓬松绝缘对空气密封几乎没有任何作用。把它都拿掉几乎不会改变你的(电子邮件保护)
      没有任何一种选择能够真正解决奖励房间漏水的所有问题。防晒系数的选择是最接近的,但这是很多钱的东西,可以用几张刚性绝缘材料,罐装泡沫和大量的体力来修复。
      这听起来不像是你永远的家,我不会花很多钱来解决一个舒适的问题。我认为一种介于两者之间的解决方案是把地板密实地铺好,然后把暖通空调的馈电增加到房间里。你可以试着单独密集包装,因为它可能会让这个地方在短期内足够舒适。
    2. 特雷弗朗伯||# 9
      即使你能让房子通过吹风机门测试,他们不会质疑为什么之前的审计让房子变得更糟吗?不仅是欺诈,而且是明显的欺诈。可怕的建议。
      Zephyr7||# 10
      我同意选项一是坏消息。这绝对是一场骗局,你可不想惹上麻烦。另外两个选择都是诚实的选择,所以我会选择其中一个或其他完全不同的选择。
      当你要封住你能看到但够不着的东西时,喷雾泡沫是很好的选择。例如,这可能包括屋檐附近的密闭空间。这不是我通常会推荐喷雾泡沫的小众应用之一,但在你的情况下,它实际上可能是最好的选择。我在这里会使用封闭细胞,原因是你可以用更薄的封闭细胞层来获得更好的空气屏障,你可能很难在密闭空间里得到很好的应用。我的工作人员以前在类似的区域遇到过问题,因为他们不能操作泡沫枪和软管,以一个良好的角度喷洒一些区域,这使得他们很难在一些地方均匀地应用。
      与其他形式的松散填充绝缘材料相比,纤维素更适合作为空气密封不良的阁楼地板的创可贴。如果阿科斯是对的,而且你不打算长期住在这个房子里,选择3可能是你最好的选择,因为它可能会有帮助,尽管它不是最优的,而且比其他选项便宜得多。
      当你准备在缅因州建造你的新房子时,来问我们的Q+A人员更多的问题:-)当你从一开始就计划好它时,做好空气密封工作是很容易的。只要确保你的计划包括空气密封和信封的东西-不要试图在裱框开始后做。从一开始就计划建造一个紧凑的家,一切都会更容易,也更便宜,做对。
      1. 大卫B||# 11
        感谢你们三位的想法——我想我们将选择选项3。来的那个人是屋主,有执照的ME,看起来是个直来直去的人。我希望在地板下增加更多的绝缘材料,在膝盖壁上设置一个空气屏障,可以在不花费巨大的情况下合理地改善舒适度。我稍后会更新这个帖子,让大家知道结果!
