我试图源3/4英寸厚Coroplastn Maine
Has anyone had luck in sourcing thicker coroplast sheets near Maine?
The one sign maker i contacted said his vendor will only supply full units and not single 4×8 sheets…
http://corrugatedplastics.net/19mmCorrugatedPlasticSheets.html
Thanks Michael,
Deal is I only need 2-3 sheets, not 10... most distributers only deal with larger order numbers appearantly
Kevin, 3/4" (19mm) is unusually thick. If you keep asking around you might find a signmaker who can get you a few sheets, though. Is there another material that would serve your needs? Could you double up more common 10mm sheets?
https://corrugatedplasticsheet.net/manufacturers/corrugated-plastic-sheets/
You might call your nearest laird plastics (lairdplastics.com). They don’t appear to have a location in Maine, but they’ve always been helpful when I work with them, and they’re pretty big, so maybe they can refer you to someone close to you that can help.
Bill
https://www.silverinstruments.com/product/flow-measurement
https://www.bizatmobile.com/about.html
