去年冬天我帮助我朋友,康涅狄格remodeler andFine Homebuildingauthor Chris Green, build and install a kitchen. We used biscuits to align the face frames on the cabinet boxes. Late one afternoon, I made a lazy move. Instead of repositioning a tall cabinet to cut a biscuit slot near the top of the box, I reached overhead with the joiner. The tool slipped and mangled the inside edge of the plywood. I was embarrassed, but Chris didn’t flinch. He walked to the other side of the room and came back with his West System epoxy kit.
“For repairs that are more structural in nature,” Green said he prefers West System epoxy over other wood fillers. “It’s a super adhesive and gap filler all in one. The ability to adapt the viscosity from a maple-syrup consistency to mashed potatoes and everything in between is a huge advantage.” The one downside, he told me, is that it is slow drying.
The thing is, you don’t have to make a mistake like I did, to find a use good use for an epoxy repair kit. Where these products really shine is on exterior repairs, often the result of poor flashing and water management details, the kind of thing green builders are often called in to fix. I’ve seen large sections of porch columns successfully rebuilt with epoxy. Yet I’ve been warned to proceed with caution.
South Dakota woodworker and remodeler Ben Brunick has done extensive repair to damaged window sash and other exterior trim with epoxy. He is quick to remind me that unless you first fix the problem that is causing the rot, you are wasting your time. The wood around the repair will just continue to degrade and the repair will fail.
本最近......
3 Comments
I've used the Abatron WoodEpox on numerous repair projects, and it is a great product. Sands easily, binds well to the existing wood, and never cracks. If there is a negative, set-up time is a little long, especially in colder weather.
我建议先进的维修技术的木制品Flex-Tec HV和Prime-A-Trate。(http://www.advancedrepair.com/unique_features_flex-tec-hv.html)
Primatrate is a 2 part epoxy wetting agent that penetrates into wood fibers. Before Prim-a-trate sets up, apply Flex-Tec, a 2 part epoxy. Flex-Tec is easy to work and does not sag. Has no VOCs. Once hardened (1-3 days), it is sandable and paintable. Flex-Tec will adhere to its hardened self, so it can be built up. I have used it to repair defects on Victorian porch details.
I do a lot of restoration work on the coast of Maine, This is a great article and I use Abatron for
根据修复的性质,其他人的一些项目和西系统。如果它在自然中的化妆品,木材EPOX就是恒星!如果需要更多的结构债券,您需要确保我更喜欢西系统的强有力。检查他们的填充物和我的新收藏:G-Flex产品。我学习了木船维修和旧房屋恢复项目的最佳作品,并且他们都有特殊的品质来利用,具体取决于需要和可加工性。
Ever messed up with router on a to be painted wood part? Wood epoxy is a life saver! fill it and rout it again.
登录或成为发表评论的成员。
Sign up Log in
