Wood and cement are great building materials in their own rights, but they can combine to yield a superior wall cladding system. It is still all in the details, however.
In general, exterior above-grade walls should have continuous air, water, and thermal barriers.
Installing rigid insulation as the exterior sheathing can accomplish all of these tasks, but you need to account for shear resistance (provide wall bracing) in other ways, and you must provide special details if you expect the foam sheathing to perform as a water-resistive barrier (WRB).
A double-stud wall insulated with dense-packed cellulose is an excellent thermal barrier; however, double-stud walls still need at least one additional air barrier to limit air leakage through the cellulose.
Check out theadvanced framingsection of Construction Detail Library for alternative techniques to achieve shear resistance, and check outUsing Rigid Foam As a Water-Resistive Barrierfor more information on walls without housewrap.
For more information on air barriers, seeQuestions and Answers About Air Barriers
