GBA标志水平 Facebook LinkedIn 电子邮件 Pinterest 推特 Instagram. YouTube Icon 导航搜索图标 Main Search Icon Video Play Icon 加图标 Minus Icon Picture icon Hamburger Icon 关闭图标 Sorted
社区and Q&A
墙壁挂厕所的品牌和模型建议
Andy Fellenz|发布了General Questions在
I’m looking at potentially two wall hung toilets in the ranch home I am rehabbing – one in the basement to avoid the need to jackhammer the floor to install the drain and one in the master bath for aesthetics and ease of cleaning the floor around it.
I’m finding a lot of different models available. From personal experience does anyone have either positive or negative recommendations?
加入建设科学专家的领先社区
  1. Mark Nagel||#2
    Timely as I was starting to dig into bathroom bits for my build plans.
    略有不同的壁挂式:
    https://swissmadison.com/collections/all-toilets/products/sublime-back-to-wall-concealed-tank-toilet-bowl
    看起来像这样,墙壁安装都需要坦克和墙壁上的后面安装的所有相关位:并且注意这是一份额外的成本(总成本推动USD 1K USD)。可能是有一些可用的访问面板的好建议:我想在所有的管道连接时考虑到这一点。
    WARNING: whatever you do don't look at the pricetag on the Kohler Intelligent wall hung one. It's a stinker of a price! (and reviews don't seem great)
  2. Expert Member
    阿科斯||#3
    I would stick to brands that have been making these for a long time. Can't go wrong with Toto or Duravit. Not sure how much I would trust local manufacturers. Also make sure there is local support, even the best toilets will need valves swapped out over time and it is a pain if you can't find it locally.
    我和我家的一个悬挂厕所之一挂了一件悬挂式厕所,这已经很好地工作了,但我确实必须从英国订购更换填充阀门。
  3. 杰米B||#4
    阿科斯, you're near me, what brand did you use?
    Andy, I used caroma wall hungs in my latest build. They work well and they're good toilets in terms of cleanliness, flushing, splash out, streaks, etc. But please be warned, there are real nuances to installing wall hung toilets mostly in the preplanning.. I put them in myself because I don't know any plumbers that put in wall hungs before, Or would come back every so often to during the different phases of construction. So I went through the hard knocks learning the intricacies myself. And let me tell you, they're nothing like floor mount toilets. Not wrong or bad, just different.
    Hope that helps,
    杰米
    1. Expert Member
      阿科斯||#6
      杰米,
      我不记得这个品牌,我在海外箱子店。有时让我疯狂,有多便宜,更好的躺椅标准设备在海外。坦克+碗是250欧元的东西。
  4. Jonathan Lawrence CZ 4A新泽西州||#5
    I have both Gerberit and Toto and here are my observations:
    - 无论是一个相对容易安装,您只需要在安装之前确定您希望座椅高度有多高;
    - Gerberit is compatable with a lot more toilet bowls, Toto is only compatible with its own bowls;
    - Gerberit has a much better selection of wall plates;
    - 每次吸吮提供的说明,但这是典型的管道产品;
    - 碗易于安装,但请确保您有垫圈。托托配有垫圈,但你必须用格伯里斯购买套件;
    - 如果您计划获得坐浴盆座椅,TOTO包括墙面框架中的水线连接器。杰贝特当时没有,但我最近没有检查过。
    - 他们真的确实拯救了大量的空间,它们看起来更好,我会在下一个项目上使用它们。
    1. 约翰泰勒||#9
      To keep the water noise down we went with cast iron DWV pluming. After seeing the thin plastic drops TOTO supplied with the kits we ordered the cast iron drops.
      Our wall framing is 2x4. To reinforce the 2x4s we screwed 1/4"T x 3"W x 60"L steel flat bar to the 2x4s.
  5. Steve Knapp CZ 3A Georgia||#7
    我没有听说过瑞士麦迪逊。看来公司大约五岁,它主要作为中国制造赛的进口商。亚马逊的一些审稿人员抱怨失踪部分,但这些评论可能与大流行有关。
    我们已经购买了最后几次,但对他们的表现有点失望。
  6. Mark Nagel||#8
    史蒂夫,在看到科勒网站的Kohler的可怕评论后,我只抓住了瑞士·麦迪逊。我拿出一粒盐的评论,大多要求在我有一个真正的真实世界表现之前需要大的样本量;我知道有问题的人更有可能评论/审查而不是那些没有的人。听到与托托的任何失望有点困扰,因为我认为他们是金标准:我打算用Toto取代我当前的地方,但是当我开始考虑一个完整,新建。
    I was feeling kind of excited about these wall mounts (and the ones that go right up against the wall- sit on the floor but have the tanks in the wall) until I started thinking about maintenance and my environment/context. I'm on a well. WC tanks got a bit crudded up (rust); I have done a lot of work to mitigate all this (long story), but it just sits there in the back of my mind; it's a feeling similar to thinking about on-demand water heaters caking up with calcium (I don't have calcium issues), having such units installed inside walls (which, of course, one shouldn't do, but you get the idea). Also, having water connections in a wall makes me a bit nervous: I realize that hidden connections are common; it's just something that I'd have to get over I suppose.
    人们评论Kohler产品抱怨水不足。科勒说要提高水箱的水位:对我来说似乎非常明显!我没有查看安装文档,在这种情况下也许它在那里注意到,但似乎应该是安装后的接入点:可以在商业安装中看到访问面板;如果您没有从用户端看到一个,那么墙的背面就有一个。
    I think that for one of my bathrooms I could provide access to the back side of the wall from a closet.
