Closed cell spray foam over moist brick and mudsill
Hello,
A duplex I recently purchased has a moist crawlspace including moist brick and water-stained mudsill (see pictures). I believe most of the problem comes from missing or poorly placed downspouts. The area around the foundation is also poorly sloped. I intend to fix all of those problems.
Recently, a contractor cleaned out the crawlspace and placed a vapor barrier on the ground. He intends to use closed cell spray foam (Demilec HFO Heatlok High Lift) up to R-10 onto the brick foundation, mudsill, and rim joist. However, the brick foundation is a bit moist. I’m thinking I have to put some dehumidifiers down there to dry out the foundation and mudsill before they apply the spray foam. Is that correct?
Thanks for any advice.
If the foundation is wet you risk problems with the spray foam not adhering properly. It is a good idea to try to dry things out before applying spray foam.
If you expect to have ongoing moisture issues with that wall you’ll want to allow a way for the wood structure to dry if you can’t install a capillary break.
Bill
Thanks, Bill. I'll solve the moisture problem before I apply the spray foam. Capillary break would be hard to apply in this situation. I may just install a dehumidifier for a few weeks and get a mason to repoint the outside to keep moisture from being sucked in from the outside. Lots of gaps in the foundation currently.
