GBA Logo horizontal Facebook LinkedIn Email Pinterest Twitter 我nstagram YouTube Icon Navigation Search Icon Main Search Icon Video Play Icon Plus Icon Minus Icon Picture icon Hamburger Icon Close Icon Sorted
社区and Q&A
Dirty sock syndrome
Wynn White|发布Mechanicals上
A friend, here in Baton Rouge, replaced his two 20 year old furnace and AC (not the duct work).
He now has dirty sock syndrome from the downstairs unit, but not the upstairs unit. Never had the problem before changing units.
他能做些什么来阻止气味(哦,他在线圈上有紫外线)。
Wynn
  1. Riversong||#1
    Take the dirty socks off the return register.
    Could you be more specific about what you mean by "dirty sock syndrome"? Is it a musty smell?
    可能是新单元以更高的速度移动空气,并在管道中捡起现有的碎屑(是否清洁了管道?)。您还可以尝试断开紫外线的连接,以查看是否有所作为。
  2. Wynn White||#2
    His AC contractor disabled the UV lights. That made no difference.
    The smell occurs when switching from heating to cooling and lasts for 2 weeks. If he has to heat, it goes away--then returns when the unit switches to cooling.
    The fan is sized the same.
  3. Robert Hronek||#3
    我t seems strange that he has a problem at switch over plus 2 weeks is a long time. the smell at the start of the heating season is normally from the dust buildup on the heat exchanger being burned off. That usually goes a way after a day or 2.
    What type of UV system did he have. There was, don't now if it is still made, a system by Trane or Carrier that has a 4 inch filter, 6 UV light bulbs and a catalyst. I ran across one at a customers house. A quick look at the manual showed that the UV lights did not kill germs, virus, etc. The filter/light/catalyst was to filter and stop odors. It required that the lights and catalyst get replaced each year. Oh and the lights looked light short florescent lights.
    Then there is a UVC light. The C part of the UV spectrum kills small living organisms in the air like viruses, bacteria etc. It will kill mold spores that get by a filter. If it is mounted above the A coil it will help keep the A coil and pan free of growing organisms. UVC lights have an effective life of about 12 months. They will still produce light but UVC light output diminishes and then they are no longer effective.
    You said the AC and furnace were replaced but was the A coil replaced.
    我would suspect there is something in the drain pan for the A coil. When AC season starts it gets wet and gives off an odor for a while. Later when the AC if off and the furnace starts operating the drying of the debris in the A coil pan smells.
    我would also look for signs of water that has leaked into the furnace.
    我should have asked if the furnace in a crawl space or an area that has a lot of humidity. Does the duct work sweat.
    No other part of the system should be wet. It takes moisture for something to grow or rot.
  4. Wynn White||#4
    Thanks for your input.
    没有爬网空间。这些装置位于地板上。一个人服务于楼上,楼下的问题单元。
    我haven't looked at it yet. I asked him to call me the next time it happens.
    我f anyone else has a flash of brilliance, please add to this thread.
    Wynn
Recent Questions and Replies
