Dishwasher plumbing connection
刚买洗碗机可以在以前没有的房子里安装。我知道他们通常附加到垃圾处理,但也没有其中一个。我很好奇,如果我可以剪切这个水平线,连接两个水槽并在这里绑在这里或我需要采取不同的方法?我知道必须高于陷阱,但不确定我有什么选择。谢谢
GBA详细资料库
由气候和房屋部件组织的一千个建筑细节的集合
搜索和下载施工细节
Do you really want to delete the list,还
这不会删除您已保存的文章,只需列表。
在Beta网站预览期间,此功能已暂时禁用。
布伦特,
您最好的选择是为“洗碗机连接”进行Google图像搜索。图表更容易遵循我们可以在这里给出的任何描述。
我从未在水平管道上看到过他们,只有垂直的管道。
I agree with Malcolm. You will need to drop your trap lower, with longer tailpieces. One tailpiece should have a T where you connect the dishwasher drain. The drain needs to be above the P-trap.
重新培布洗碗机 -
不要忘记通风要求(即气隙VS高循环方法)。再次,谷歌是你的朋友,“洗碗机通风要求”。一些社区需要一种方法或另一个方法,所以值得检查这一点。使用高循环方法避免必须在台面上放置一个孔。
顺便说一句,如果你有能力做自己的管道,放入垃圾处理不是最糟糕的工作,垃圾处理并没有过于昂贵并且非常方便,所以你可能会做一些计划你的铅平和洗碗机一起。imo。
Also,
Just FYI... the current drain would not be code permitted anywhere I'm aware of anymore. The pipe going straight through the floor with an elbow taking the input of the P trap effectively creates an S trap which is prone to siphoning.
If it works without siphoning, I wouldn't worry about it. If you ever hear gurgling noises coming from your sink that you can't account for, now you know why.
最简单的修复是用沿着P陷阱的输入替换通过地板的排水榜上的肘部。清洁剂的顶部将具有尽可能高的管道上运行,空投阀门安装在其顶部。
谢谢for the replies fellas. I have seen some images of people tying into the horizontal pipe but they are always the "what not to do photos." Patrick, thanks for updating me about the s-trap vs p-trap. There is no vent on this line, the sink is on its own line so to speak, it goes straight down through the floor and straight under the basement floor and then ties into my floor drains before it leaves the house. I have never heard it siphon or gurgling my guess is because there are no other drains on the line that would be pulling air out of the trap? Is that correct?? It appears there is enough excess pvc coming from the bottom of the cabinet that I should be able to just cut it and lower the entire assembly. This dishwasher retrofit is beginning to be more of an ordeal than I originally planned, but what DIY project isnt! haha
提到的空中入场阀门帕特里克是您最简单的“修复”在这里,您有足够的空间来添加一个及其易于做的。在某些情况下,即使没有其他排水管在同一条线上,也可以让陷阱虹吸。有一种奇特的通风方式,看起来像颠倒的“U”有时与厨房岛屿一起使用,但这似乎并不是你在这里的目标。
顺便说一句,有两种类型的洗衣机available for the trap connection rings: the hard milky-colored ones and rubber ones, usually red. The rubber ones seal much better and are less prone to loosening and leaking on kitchen sinks where you sometimes pour hot and sometimes cold water down the drain. When you put your drains back together I’d make sure to use the better washers. The better washers have solved a lot of kitchen drain leak issues for me.
账单
账单,
我更喜欢岛屿水槽下的循环和芝加哥通风口。他们占用空间,但不要依靠机械部件工作。它们可以连接到远程通风口,或者如果流入的管道足够大,则不需要通风口。
For the OP it's too late to add a Loop vent, so an AAV is probably the only option.
The siphon effect is created by the water going down the drain in question, not due to air entering from somewhere else. What might be the saving grace for this set up is the line for the left side provides a vent for the right, and vice versa. This is not the case if both sinks are filled, obviously. Since you are redoing it all anyone, now would be the time to install an AAV.
Don't install a garbage disposal unit if you happen to be on a septic system.
“如果你碰巧在化粪池系统上,不要安装垃圾处理装置。”
I'd add: Don't install a garbage disposal unit on any house. All they do is masticate things that shouldn't be put down the drain, and add more solids for the municipality to extract and treat.
@ Malcolm, r.e. garbage disposal installations in general -
如果您没有统治规定(公寓,无所畏惧,无论是什么原因),整个环境都会更好地为您的垃圾或您的Glburator提供修剪(大多数水果和蔬菜)吗?如果他们进入垃圾和垃圾场,我认为他们最终会产生甲烷。严肃的问题,如果这最终劫持线程,请不要知道回答,并向原始海报道歉。
最小化食物垃圾显然是最重要的因素,但不可避免地有一些你不能吃的有机比特。
