Home-brew wood preservative
I recently received an e-mailed question from a friend who is building a house in Costa Rica. The topic is beyond my technical expertise, so I’m turning to the GBA community in hopes that a chemist can provide useful advice.
Here’s what he wrote:
“We are about to treat the wood for our ceiling in the house we are building in Costa Rica. The wood is what they call here Laurel —Cordia alliodora。正如柚木那样,它对昆虫没有特别抵抗。木材应该保持干燥,不会暴露在雨中或飞溅。
“We were going to use Xylibor wood preservative, but it has hexavalent chromium, which I really want to avoid. So I searched the web and found a lot of copies of home-brew recipies for Timbor and Boracare. We made a batch of the Boracare copy using borax, boric acid, and propylene glycol, but heating propylene Glycol to 260 degrees F is scary (hotter than flash point), and the high concentration of glycol discolored the wood and left a blotchy look. Also the high borate concentration left a coating of white dust.
“So, we switched to making the home-brew Timbor. We made both the 10% and the 15% versions. Both worked fine, dried easily, and left no white coat of borate crystals. I also tested adding a tablespoon of propylene glycol to a cup of the 10% solution, and 2 tablespoons to 1 cup of the 15% solution. The added glycol slowed the drying noticibly, but not beyond what is practical for us.
“Is there any problem with having glycol in wood under a clear acrylic finish (tekwood)?
“What is the purpose in the home brew Boracare recipie of heating the mix to remove the water of crystalization?
“Why do both these mixtures need to be used quickly?
“Is this home brew 15% Timbor solution effective against termites and powder post beetle?
“Does it make sense to add the propylene glycol for greater penetration and for its anti-fungal and insecticide properties?
“We also plan to add Dragnet, a permethrin product.
“Thank you for any light you can shed on this topic.”
任何GBA读者都希望在这里提供建议吗?
Martin, I'm no chemist but it seems like many of your questions are anwered here:https://sawmillcreek.org/showthread.php?233066-Home-made-bora-care-amp-timbor。说明说加热溶液使其使其稳定;在应用之前它与水混合时,它必须快速使用它。我想象它可能与水中和酸性混合物有关,但我不确定。
The glycol compound is a surfactant. There are differences between glycol compounds (polyethylene, propylene, etc.) but probably not enough to matter for this application. Woodturners often use PEG (polyethylene glycol) to displace the water in green blanks. More info here:http://www.woodweb.com/knowledge_base/using_peg_for_dimensional_stability.html.。如果您将解决方案涂抹在干燥的木材中,可能没有理由使用乙二醇化合物,并且显然它可以在温暖的天气中渗出,因此如果可能的话,我倾向于避免它。
迈克尔,
Thanks very much for your helpful information. Much appreciated.
