我如何知道哪个整个房子除湿ifier是最适合我的房子以及如何找到最好的公司安装它?
I’ve looked extensively on the internet, perhaps not using the best search terms, and have found no information about the best size and brand for my house, which is between 3000 and 3500 square feet, or how to find a company to install it properly, which according to a “This Old House” video that I did find, is very important. I have had two estimates for both these things, but don’t know how to check their credentials. Thank you!
GBA详细资料库
由气候和房屋部件组织的一千个建筑细节的集合
搜索和下载施工细节
I'm curious why you want a whole house dehumidifier vs one or two portables.
正如我认为乔恩在暗示的那样,你必须小心没有使用除湿器来绑架更重要的问题。
他们所说的 - 为什么你认为你甚至需要它?
除湿机通常只有appro整个房子priate for house in regions with high outdoor dewpoints and the house has VERY high ventilation rate requirements, or in houses with very high indoor humidity sources. Is there an indoor pool & hot tub that are normally left uncovered? Is the house chock full of heated tropical fish tanks?
Earlier this summer, this area had weeks of ~75F very humid weather where dehumidification was necessary for good comfort. But combined with open interior doors (or, if you really have to, a furnace fan), portables should be sufficient. Even more so as houses are better air sealed.
我已经看到了一些关于整个房子除湿机效率的疯狂主张 - 400%我的计算显示50%(并且没有计数炉扇电源)。排除夸大的安装人员。
关于大小,我假设过度尺寸对效率产生负面影响。也许A.[email protected]测量估计ACH - 天然峰值?
能源之星额定的便携式符合额定值约为1.8升/千瓦时。我认为350美元有2.0美元。但是,热盒制成的除湿剂,包括独立(但不是真正的便携式)地下室/爬虫单元以及管道单元,包括高达4.2L / kWh的型号。因此,使用能源之星便携式的能量不到一半。它们更昂贵。
Thermastor拥有不同的品牌名称,适用于独立和管道单位:Ultra-Aire和Santa-Fe,但这两条线的阵容非常相似。
我怀疑,但并不真正知道,在带有管道周围分布除了房屋周围的除湿性不如分配热量和冷却。因此,获得一个超效率,并将其放入一个地方而不是将其绑在管道中可能不是一个坏主意。
莱德勒,
你收到了好的建议。认为他们需要全部除湿ifier的大多数房主实际上都有一系列最佳解决的问题。这些问题包括:
1. A leaky thermal envelope (leaks through the floors, walls, and ceilings of your house).
2.过挡板(每天运营通风风扇太多小时)。
3.让Windows打开的家庭成员。
在大多数情况下,您需要做的就是减少通风率,关闭窗户,密封大空气泄漏,并操作普通的空调。
