How do I stop further deterioration of T-111 wood siding
我造成这个问题当我添加了一个甲板e, lag bolting an exterior rim joist for deck support directly to the interior rim joist with the T-111 siding sandwiched between (stupidly). I recently discovered that the sandwiched T-111 is starting to decompose due to water retention. Removing the exterior rim joist to make repairs would require dismantling the deck, which I hate to even think about. Question 1: If I can ensure that the T-111 won’t be exposed to further significant water (through siding), will I have already set up a “dry rot” situation that will eventually compromise the underlying structure? Question 2: Assuming the answer to question 1 is “yes”, is there any thing short of removing the outside rim joist and replacing the T-111, perhaps an oil based preservative that could be applied at exterior joist/T-111 interface that would penetrate the degraded siding and arrest further decay? Thanks for your help.
If your situation is like mine (and it sounds like it) you wouldn't have to dismantle the ENTIRE deck. Our decking runs parallel to the wall. We will pull up 3 feet of decking, and place a temporary beam 3 feet from the house to carry the load. Then we'll dig into the ledger and wall problems. Haven't decided yet whether to hang a new ledger with a gap and flashing attached to the house, or else turn that edge of the deck into a cantilever with some new supports close to the house. In any case, we don't have to dismantle the whole thing, just 3 feet of decking, and we'll put it back down when done.
Good luck
Pretty hard question without pics / seeing it
Siding won't fix the issue - proper flashing will & maybe enough to help prevent further damage
If you have to remove / rebuild, first make sure it is flashed properly , go with a stand alone deck, or use a product like Deck Spacers
George,
You cannot arrest the rot. You will have to remove the existing deck ledger, regardless of what is involved, remove the rotted T-111, check for rot in the house rim joist and repair as necessary, and then properly flash under the T-111 and over a new (or reused) deck ledger. Rhino plastic deck flashing will stand up to the chemical treatments in the deck wood better than tin or aluminum flashing.
If the T-111 is disintegrating, then it's likely that there's rot in the house framing as well.
A deck ledger needs either to be spaced or flashed with Z-flashing. I prefer the flashing, since bolting tightly to the house creates a stronger connection and exterior decks have to be engineered for at least 60 psf live load, and more if there is any possibility of impact loading from snow off a roof above.
http://www.finehomebuilding.com/how-to/articles/get-your-deck-off-to-a-good-start.aspx?ac=ts&ra=fp&collection=72676
