棒子上的外部木镶板吗?
bp8963|Posted inGreen Building Techniqueson
你好,
我和我的伴侣位于法国。我在缅因州长大,被发现了农舍。我们正计划建造一个COB房屋以提高成本效率;但是,几年后,我很好奇是否可以在稍后再添加木材的木质壁板?再次,我非常喜欢农舍的外观。有建议或建议吗?非常感激。Merci Beaucoup。
GBA细节库
搜索和下载施工详细信息
通常的平坦结实的墙不是super-planar, but I suppose you could make it fairly flat. One of the nice things about cob it the ability to make unusual shapes and curved surfaces, whereas most wood cladding tends to be fairly straight, which could be a practical/aesthetic issue if the underlying wall isn't very flat. As long as the wood cladding is back ventilated, with an air gap between the cob & cladding as a capillary break and drying path it should be OK from a moisture point of view.
The topic has come up before on this forum:
//m.etiketa4.com/community/forum/green-building-techniques/18345/exterior-side-cob-walls
BP8963,
The question hinges on fastening. If you know how to securely fasten vertical furring strips to a cob wall, then you should be all set.
我认为墙壁大会将受益于WRB(也许是房屋包),但是您可能对WRB的想法有哲学上的反对意见。无论您是否包括毛茸茸的条和棒墙之间的WRB,您都需要毛茸茸的条。找到一种将毛茸茸的条(也许是长螺钉)固定到棒的方法,您应该全部固定。
The furring strips can be shimmed as necessary to get the furring strips co-planar.
BP8963,
Some online research reveals that fastening furring strips to a cob wall won't be easy. I didn't come up with any great suggestions after reading these links:
http://www.greenbuildingforum.co.uk/newforum/comments.php?DiscussionID=2883
https://forums.pigeonwatch.co.uk/forums/topic/290174-gun-cabinet-fixing-to-stonecob/
https://community.screwfix.com/threads/cob-walls.4403/
I'll confess to being bewildered by this post - why on earth would you want to do this? First of all, if cob is an economical building material in your part of France the chances are it already 'is' the farmhouse look in your area. Farmers are generally pragmatic and economical people and the farmhouse 'look' in any given area generally reflects environmentally responsible local material options and construction technologies which local builders are thoroughly familiar with.
但是,鉴于您似乎确实对缅因州农舍的外观有所努力,因此将壁板添加到COB会带来一些实际困难,这些困难可能具有昂贵的解决方案。As Martin has discovered, fastening nailing battens to cob is not going to be an easy matter and you’re likely to end up needing to build a full frame wall spaced off the exterior of the cob, maybe in pressure treated material and with the need for careful and complicated detailing at doors and footings and most especially at window openings. And then you will have a non-indigenous exterior cladding material which will require regular maintenance much in excess of the original cob. Sounds like a recipe for much trouble and expense.
詹姆斯:当地的“ ...农舍外观……”在法国的大多数情况下,比棒子或木质覆盖物更有可能是石工砌体,而且绝对比COB贵。也可以找到法国农村的Cob&Stone房屋的例子。
也就是说,实际上并没有将木质覆层添加到COB结构中的弹性案例。体面的屋顶悬垂和屋顶线条旨在防止反复的暴雨湿润湿是个好主意,但棒子本身是相当韧性的。坚持木材覆层限制了形状范围,否则这些形状范围可能会提供大量的性格和建筑香料,而与COB一起使用的形状也可以提供。在我看来,拥抱材料的灵活本质,而不是掩盖它以使其看起来像其他东西更合适。YMMV。
Dana: certainly, stone is the common traditional building material in the parts of rural France that I’m familiar with, and brick or concrete masonry with stucco finish a more economical modern alternative. I wouldn’t consider cob a good choice if there were no local tradition of its use, there are many parts of France I have not visited and I was giving the OP the benefit of the doubt on that.
有趣的想法,我有一个相似的想法,但相反。建造一个相当传统的建筑物,符合本地代码,并与分包商所用的东西一起使用,以将成本,复杂性和骚扰保持在最低限度,然后在建筑物内建造棒棒。我的一天的梦想是使它完全摆脱侧面和屋顶,并创建一个非常有机的形状。然后,您不会受到直角,盒装形状或与屋顶连接的芯子的约束,并受到最差元素的保护。您可以将建筑物作为您的表格,填写,但是我喜欢巨型公用盒子内的雕塑房屋或封闭的门廊的想法。
