Lunos HRV system in cold climate?
We are building a 1,350 square foot single story passive solar home. Slab on grade, very well insulated, open concept living area, 2 bathrooms, 3 bedrooms. Our home is located in northwestern Ontario, Canada, with temperatures dipping to -30 degrees Celsius in winter. The winters are dry. Wondering if anyone has experience with the Lunos HRV system in a cold climate? Would there be issues with the heat exchange during cold days/nights? What about extreme differences in inside and outside humidity?
Vera,
I suggest that you call one of the specialists at 475 High Performance Building Supply and ask them your question. (They are a major supplier of Lunos fans.)
Contact information:
131 Union Street
Brooklyn, New York 11231
718-622-1600
800-995-6329
This is just a fuzzy memory, but as I recall the manufacturer claims to have tested them in northern Norway, which can easily be -30C or colder. The concern was whether they would suffer frost damage in real-world house at those temperature extremes, but apparently they're fine.
Rather than relying on the folks at 475, you might try getting information from the manufacturer:
http://www.lunos.de/en/
Vera,
Did you ever find an answer to your question? From what I'm finding in the Lunos literature, the temperature application range is -15C to +40C
Steve
