Remedy for smelly duct coating?
A contractor appliedFiberlock IAQ 8000over fiberglass insulation in my ducts to keep the fiberglass from going through the ducts. I have now a paint smell.
Will it offgas even when the smell disappears? What is an alternative material?
Thank you
Gene
gene fialkoff
[email protected]
8024966668
Gene,
According to the manufacturer's literature, Fiberlock IAQ 8000 is a "pigmented latex emulsion coating comprised of water, pigments, fillers, additives, and latex emulsion resin" — in other words, it's something like latex paint.
The application instructions advise, "Circulate fresh air through the HVAC system to help dry the coating. Exhaust air outside the building." The instructions also note, "Do not apply when air or surface temperature is below 50°F or when drying conditions are poor. Use adequate ventilation."
I assume these directions were followed. How long has it been since the product was applied? Does it still smell?
yes - except not sure of 1st
applied about 10 days ago
Gene,
I just receive a call back from Fiberlock. One of their reps, Angus, told me, "It's just a question of time. Once it dries, there is no smell. While the product dries to the touch in about an hour, full curing might take up to 7 or 10 days. Usually the smell dissipates in just a few days, but curing time is a function of temperature and humidity, so each situation is different."
thanx
do you know an alternative
they say their product contains one ten thousands of 1% of formaldehide - worriesome after smell disappears?
