We’re all still getting used to using Zoom for meeting and webinars and group discussions, so it took us a few minutes to get the show rolling this week (we edited that nonsense out of the video), but we ended up having an excellent discussion about costs and building high-performance homes with a panel of experts includingAlan Gibson,,,,兰迪·威廉姆斯,,,,克莱尔·贝兹(Claire Betze),,,,本·博吉(Ben Bogie),,,,克里斯汀·威廉姆森, 和丹·海因斯(Dan Hines)。享受。
Next show, April 16, 2020:一个面板将讨论如何设计和建造无混凝土板的房屋。观看GBA和FHB新闻通讯和社交媒体,或者下周在此处查看有关如何现场调整的更多信息。
-You can reach Brian Pontolilo at[email protected]
4 Comments
由于你们都是一个如此多样化且经验丰富的小组,在一个地方聚集在一起,所以我想借此机会提出一个我没有找到令人满意的答案的问题。
我已经建造了一栋“高性能”房屋,该房屋价格合理,并且有一个明显的问题舒适且节能效率。当它加热并冷却时,它会使巨大的爆炸声令人震惊。它是使用8英寸SIP墙板和12英寸厚(4'x20)大教堂天花板构建的,这些天花板的长跨度接头。我认为没有任何简单的解决方案可以消除问题,但是我的问题是你们中的任何人都听说过这个问题,有人认为这会导致长期问题。我已经在屋子里呆了大约4年了,令人震惊和令人震惊的大声流行音乐没有改变。谢谢,这个论坛是一个好主意。
夏天,我常规框架和绝缘房屋的朝南墙壁弹出。我怀疑这是您所经历的现象 - 材料在扩展和收缩,并在绑定时弹出。随着时间的流逝,它并没有减少,不幸的是,它也可能不会在您的家中。
Differentpath, that is a common problem with timber-framed houses, and any house framed with wood will have some popping as materials change dimension with moisture content. It may have something to do with the monolithic nature of stress skin panels--wood, drywall and foam all expand and contract at different rates, depending on moisture content and temperature. If it does not compromise your air control layer, it is probably not a problem. If it does compromise your air control layer, you may end up with the sheathing rot that can happen on SIPs-clad buildings.
“ [删除]”
登录或创建一个帐户以发布评论。
注册 登录
