图片信用:团队MTL
ecocor是高性能结构板的缅因州的缅因州,正在前往中国。
The company says it has signed on as the industry partner forTeam MTL是一群来自麦吉尔大学和蒙特利尔的Concordia大学的学生,魁北克省进入Solar Decathlon China明年竞争。
Team MTL is one of 22 groups that are designing and building high-performance homes for the competition. It’s the second Solar Decathlon to take place in China after an inaugural event in 2013. Modeled on the U.S. Department of Energy’s biennial Solar Decathlons here, Solar Decathlons also take place in Africa, Europe, the Middle East, and the Latin America and the Caribbean.
MTL’s entry uses the Passive House-certified structural panels manufactured by Ecocor for its own line of panelized houses to create an adaptable housing form called theSiheyuan庭院风格对于中国许多地区共同。
The team’s entry, the Deep Performance Dwelling, is designed with both Montreal and China in mind, according to a description of the project at its website.
“TeamMTL begins with the premise that the project design and construction must be applicable to the contemporary Montreal urban, social, and affordable housing context and northern climate as well as to the competition context in China,” the description reads. “Each site exists within the same climatic zone.”
There will be two permanent structures: the first built for the competition and a second one designed specifically for Montreal that could serve as a model for affordable housing in Canada. The design combines elements of a typical Montreal row house and theSiheyuancourtyard style of housing common to many parts of China.
Making houses that can be taken apart
Ecocor’s wall panels consist of a 2×4 structural wall and an I-joist outer wall, both of which are insulated with dense-packed cellulose. They’re assembled in the company’s Searsmont, Maine, factory and trucked to the site where they are assembled into a building shell. Ecocor and architect Richard Pedranti have collaborated on a line of Passive House certified houses that use the panels, and the same basic panel design is going into the Solar Decathlon entry.
There is one big difference: Ecocor’s houses are meant to be built once, but the nature of the Solar Decathlon competition means the house will be erected once in Montreal, where it is already on display, then taken apart and shipped to China, where it will be built all over again. Ecocor adapted its panel design to make assembly and disassembly possible a number of times without affecting performance.
Teams are required to design a two-story, solar-powered house with a floor area of between 1,290 and 2,150 square feet. The structures are to be used as a single-family dwelling in an urban area.
该房子将于10月份蒙特利尔展出,随后通过火车和船只在明年夏天的比赛中乘坐火车和船只。后来,房子将被卖给德州市,用作居住。MTL团队将使用这笔钱以及额外的贡献,以在蒙特利尔建造更多版本的房子。那些将赋予需要经济适用住房的家庭。建筑物也将用于长期研究。
ASolar Decathlon今年10月在科罗拉多州丹佛的美国在美国。
One Comment
更多关于墙壁设计
更多关于墙面设计的内容:
https://www.ecocor.us/panelized-walls.
Sign up Log in
