GBA徽标水平 Facebook LinkedIn Email Pinterest 推特 Instagram YouTube Icon 导航搜索图标 Main Search Icon Video Play Icon Plus Icon Minus Icon Picture icon Hamburger Icon Close Icon Sorted
问答聚光灯
打开墙壁时进行升级
Open walls are a chance for improvements but there are considerations to weigh before ripping off the drywall
撕下干墙移动一些内部分区是温哥华房主打算改变她1970年代牧场的一种可能性。但是,在内墙和天花板上对石棉的积极测试使她可能制定的任何计划变得复杂。图片来源:泰勒·格雷斯(Tyler Grace)。
Astrieanna has an opportunity many homeowners would jump at—the chance to completely remake the interior of a 50-year-old house.
Astrieanna lives a few hours east of Vancouver, British Columbia, in a 1970s ranch over a full basement. A friend is lobbying for the complete removal of the drywall on the main floor in advance of moving a couple of non-bearing walls to improve the floor plan.
Should that be in the cards, Astrieanna already is thinking about adding insulation to both interior and exterior walls. There’s currently no insulation in interior walls, making for a noisy house.
“在墙壁都打开时,我还应该尝试同时做什么?”她写道in this recent Q&A post。“这是我的第一套房子,这将是我的第一次大型翻新,所以我担心我不知道在墙壁开放时会方便的选择。”
一个干净的板岩和一个想做正确的事的房主。您会给批发改进的机会做些什么?这就是这个问答的焦点。
从管道和电气开始
All-new plumbing and wiring is what Ryan Lewis would do, along with installing Intello, asmart vapor retarder。
“I agree,” says Jamie B. “Plumbing and electrical improvements can have a big impact on quality of life, especially if your plumbing is older. And then you can increase capacity at that point if you want, as in increasing main diameter, adding a water line for the fridge (or future fridge that will have a water connection), washing machine (or future washing machine), his and her sinks, his and her shower heads. Add a hot water recirculation loop if you want.”
In addition to…
本文仅适用于GBA Prime成员
8 Comments
  1. Antonio Oliver||#1
    Asbestos Question:
    当房屋被重型机械拆除时,是否需要在拆除之前对房屋进行石棉测试?最近,我附近的房屋被夷为平地,这一过程产生了令人惊叹的灰尘。我必须想象,考虑到我的邻居的发展时间,有很多石棉被释放。
  2. 鲍勃·欧文||#2
    In NH, that depends on the Town. One of my jobs involved the oldest house in that Town; new owner wanted it gone. We quoted the demo & getting the permits; when we came back on Monday, they'd rented equiptment, demo'd and semi-buried everything (boards and glass sticking up everywhere). Town said "oh, well". There is a pile of used-to-be-a-house in my Town now; my guess is no one ever checked. Yes, they should, but they won't if they can avoid it.
  3. Dan Kolbert||#3
    要考虑的另一件事是它的牧场!地下室!从地下室或阁楼上击中所有东西(管道,接线)非常容易。
    Presumably it's not a huge place - running cat 5 or coax seems like a waste too. Connect the cable box and hit everything else with Wifi.
    Gutting for the sake of gutting is crazy. Spend your money on the usuals. Insulation, air sealing, more efficient equipment, PV. Nothing ""green" about throwing shit in a dumpster without a compelling reason.
  4. 艾伦c||#4
    "Cat5E cable, plus RG6 coaxial cable, which should be able to accommodate any need in the foreseeable future."
    CAT6A应该是新标准。它不多,从CAT6A到CAT7的跳跃仍然非常陡峭。运行同轴电缆很容易,但是我不确定将来会使用什么。所有新的套装顶部框都是无线的,大多数“有线电视”服务都有可以在Android TV上运行的应用程序。
  5. 肖恩·科特(Sean Cotter)||#5
    关键位置的CAT6A(单体或类似是可以的)并不昂贵。我的新电缆盒实际上在CAT6A上运行,在另一个房间的路由器位置上。如果您不介意墙壁上的空白插座盖,您甚至不需要终止电缆。只需将8-10英寸的服务循环塞入帮派盒或切割的泥环中即可。
    I think one run of Cat6a next to duplex power outlet at prospective TV locations is fine.
    Otherwise, the wiring should run to some central location (basement, home office, pantry corner).
    我仍然认为您需要RG6,CAT6A和潜在的蓝精灵/低伏特追逐您的服务到达房屋的位置。因此,从您的家(路由器将居住的地方),然后到外部有电缆,纤维等。
    总是很沮丧,看到外部通过电话,数据,固定在壁板等的电缆接线以及钻入房屋每个房间的孔中的新建结构。
  6. 美味的||#6
    我建议反对CAT6A。它比CAT6昂贵,并且很难使用 - 更硬,更重,特殊的连接器,并且难以正确终止。如果您没有合格的技术人员使用它,则最终可能会出现不通过规格的不良终止。额外的带宽实际上是仅当您需要以10克速度运行(> 50m)的10克速度时,这听起来像是这个房屋中的问题。
    FWIW, I know a pre-IPO systems engineer at one of the biggest tech companies in the world, building a palatial guest house in one of the more expensive neighborhoods in Silicon Valley. He has 10Gbit commercial grade service and calling him "picky" about his networking would be an understatement. He is wiring the home with Cat6 because he thinks 6A is a PITA and not worth the trouble.
  7. 艾伦c||#7
    CAT6A比CAT6有点僵硬,但它不应该在敞开的墙壁上有所作为,它们都用RJ45千斤顶终止。1,000英尺电线的成本差异约为150美元。CAT7是一个完全不同的故事,上面有金属千斤顶。我的理念是,将未来的网络证明是合理的,因为技术随着带宽吞噬应用程序的发展而迅速。
    I'm using Cat6a because because I'm wiring my own wireless access points and PoE devices. Most people who use the telco or cable co provided routers or modems should be fine with Cat6, even though it's only certified to 1 Gbps vs 10 for Cat6a. Admittedly, there are no household applications that use 1 Gbps (expect file transfer), but then again Bill Gates was rumored to say once that 640KB was adequate computer memory for the future.
  8. 加里||#8
    关于降低噪音和最终结论,最好是没有充分理由的理由不肠房。我认为在需要噪声控制的地方,它们可能会得到可接受的结果切割孔,用吹纤维素填充腔,并在分区组件的一侧添加绿色胶和第二层的干墙。可行有效?显然,会有一些重新修剪,但要比全肠工作要少得多。当然不如弹性频道有效,但我认为它会以更高的音调声音(声音)走很长一段路。
登录或成为成员发表评论。
Related
最近的问题和答复
