Adding Henry Blueskin inside
I have a existing log home and would like to frame a wall inside in some areas to beef up the R-value. I am thinking of adding a layer of Blueskin, then studs and batts. So from outside wall would be” 10″ log, Blueskin, batts (Roxul perhaps) and drywall or T-and-G boards. Seems the layer would stop air infiltration while being vapor permeable. Thoughts?
Scott,
Henry makes a variety of products. Some of their products with the Blueskin name are vapor barriers; they arenotvapor-permeable. (For example, check out this page:http://henry.com/airandvapor/nonpermeable/blueskinTWF.)
Here is a link to some Henry products that are vapor-permeable:
http://henry.com/airandvapor/vaporpermeable
Your plan will probably work. Even better would be a wall assembly with some kind of foam on the exterior side of the new wall. If you could install spray foam against the logs, in a kind of flash-and-batt installation, you would limit moisture accumulation and stop the air leakage.
If you choose to install tongue-and-groove boards as your interior finish material, with Roxul batts as your insulation, you definitely need an interior air barrier. Tongue-and-groove boards are not an air barrier. I suggest that you install drywall (following the Airtight Drywall Approach) before installing your tongue-and-groove boards.
Thanks Martin!
我想我会做气密石膏板应用roach. This will be for the areas that I want to preserve the exterior appearance of logs.
On the areas were I would like to preserve the interior appearance, my plan is for (from the in going out) 10" log, 3 1/2 " batts and r7 zip/foam panels. This will be covered in bark siding. Should give me a tight R 32 wall. Pretty good for my Ct. climate.
Any more comments? Thanks in advance.
