GBA标志水平 Facebook LinkedIn 电子邮件 Pinterest Twitter Instagram YouTube图标 Navigation Search Icon 主搜索图标 视频播放图标 加上图标 减号图标 图标图标 汉堡图标 关闭图标 分类
Aprilaire 8126通风控制系统
Jill Neubauer建筑师|Posted in机械on
Does anyone have any experience with the ventilation control system listed below?
Just curious how effective it is…seems to be a solution in between total passive fresh air intake and an HRV.
http://www.aprilaire.com/index.php?znfaction=productDetails&category=16&item=8126
  1. GBA编辑
    Martin Holladay||#1
    Chris,
    This equipment is used for a central-fan-integrated supply ventilation system.
    For more information on central-fan-integrated supply ventilation systems, see设计良好的通风系统。
  2. Jill Neubauer建筑师||#2
    感谢您的链接,马丁。
    That was exactly my question. How effective and cost effective are they relative to a Panasonic or Broan fan on a timer. The furnace is a 95% w/ ECM motor.
    I mean, I understand that it is bringing in fresh air mechanically rather than just allowing the pressure change from exhausting air to provide fresh air, but is it significantly better performing than just using an exhaust only approach.
    It looks like it only runs when the outdoor air is within certain humidity and temp. tolerances. Is there any worry that in a particularly humid climate that it wouldn't run often enough to meet code?
  3. 凯西||#3
    Hi Martin,
    在同一主题上...在您的文章中,您说:“对于带有开放式平面图的小房子,他们(仅排气浴风扇)很有意义。它们负担得起且节能。”什么小?我有一个2层的楼层,阁楼和大教堂的天花板和天花板峰的4个吊扇。这房子的长度超过2,000平方英尺,长32'乘40'。天花板中的R50(闭孔泡沫)和墙壁中的R32(开放式泡沫)。我有一个木炉(我正在考虑安装新鲜的空气进气口,穿过后面的墙壁。我从外面密封了所有东西与高级密封相同的密封。我可以在两个浴室中的排气风扇(一个向上,一个下降)中逃脱吗?如果我需要在楼上阁楼后面的条件储藏室里,我确实计划了专用HRV的位置酒吧。(它将与我的额外啤酒和葡萄酒共享房间:)
  4. Aj Builder, Upstate NY Zone 6a||#4
    克里斯(Chris),如果我们从手动关闭的OFF升级,那八月的设备正是我的HVAC公司使用的。手动系统的问题是房主永远不会使用手动系统。
    对我来说,任何简单的排气系统都比在最佳HRV上花费5,000美元要好,除非房屋大且高端。
    Your other option like has been posted about quite a bit is to put controls on the bath fans to run them enough to meet the code and also to condition the air to appropriate quality.
    我对空气质量的最新想法。有人提到ra系统还如何减少通过平板出现的水分负荷。我的想法是为什么不让这个粉丝履行更多职责,三重职责。如果沐浴风扇可以满足代码ACH通风需求,那么ra系统也可以。少即是多。一个完成所有操作的系统。我喜欢。我将发表帖子。
    回到Aprilaire。很棒的产品是我对寒冷气候的看法(编辑),这是我主要建造的地方。
    Edit- Warm moist climates, if using air conditioning and closing up windows, need an ERV. And may need dehumidifiers. The Aprilaire is not designed IMO for humid climates.
  5. GBA编辑
    Martin Holladay||#5
    凯西,
    中央粉丝集成的供应通风系统比仅排气系统更好地分发新鲜空气,但比仅排气系统使用更多的能量来运行。
    An HRV with dedicated ductwork has the lowest operating costs of any ventilation system, but costs the most to install.
    关于在您房屋中使用哪种系统的决定取决于您。
  6. Aj Builder, Upstate NY Zone 6a||#6
    凯西,您的房子很可能很紧。我建议现在打击门测试,并密封门时剩下的东西。然后,肯定会在ACH中闻名,在寒冷的气候下进行HRV,并在温暖的潮湿气候下进行ERV。
    如果您非常紧密并且处于寒冷的气候下,我会使用的唯一其他选择是实际上是HRV单元的松下风扇。到目前为止,这些将是最便宜的,我在这种情况下的选择。当房屋无人居住时,我也会关闭它。或者,当我只是想在床上开一个破裂的窗户而不是机械解决方案时。
    A missing link here, would also say use a standard Panasonic fan with air inlets poked thru the bedroom walls up high. Another good cold climate solution. A link to follow via edit.
    //m.etiketa4.com/community/forum/mechanicals/19471/need-hrv
    也在搜索框中搜索“松下”
登录或创建一个帐户以发布答案。
Community
最近的问题和答复
