Asbestos
Asbestos or dryer lent?
We are buying my grandmothers house (b. 1948) and there was been rodents in the house & we came across this tonight while moving the washer and dryer away from the wall.
Sorry for the bad lighting. A professional would be 4hrs away so any help would be appreciated.
Oxhouse,
It's probably cellulose insulation, but it's hard to be certain with such low-quality photos.
If you have any doubts, invite an experienced insulation contractor -- one who has experience installing cellulose -- to look at it.
没有人能确定是否presen石棉t without testing under a microscope. Most cities have a local lab and testing is not a large expense if you consider risk from exposure. Mail order testing is 30.00https://www.amazon.com/Asbestos-Test-Bus-Days-Schneider/dp/B008J3ZK8M/ref=sr_1_1_sspa?ie=UTF8&qid=1533830921&sr=8-1-spons&keywords=asbestos+testing&psc=1Walta
I agree with Martin- it sure looks like cellulose, but it's too low-res to say for sure.
If it's cellulose it will not feel the least bit itchy/prickly, and when thoroughly wetted becomes like papier mache (since it's made of milled shredded paper and fire retardents.) The fire retardents usually impart a gray appearance to the paper. Scoop a demitasse full of it and sprinkle in some water, see how easily it mixes and wets. Cellulose wets and clumps readily and can soak up quite a bit of water.
Some rock wool products will have a similar and gray look but is clearly longer fibers, and can be itchy to the skin and is more hygrophopic-it won't wet or clump very easily when wet. The same is true for some blown asbestos products, which usually have a more uniform somewhat darker gray color than rock wool.
Dana Dorsett is correct, and there's every reason to believe that the insulation in the photo is harmless cellulose.
That said, I'd like to add an important safety warning: If you suspect that you're looking at vermiculite insulation -- a type of insulation that often includes asbestos -- or if there is a good chance you are looking at asbestos pipe insulation, then you don't want to be touching it, feeling it, or scooping up a demitasse of it.
Here's the rule: Don't touch it. Secure the area and ensure that the fibers aren't disturbed. Especially, don't let kids anywhere near it.
