Attic Ventilation
I’m planing the ventilation for my attic. I’m going to have loose fill cellulose to an R-60 and a friend of mine was mentioning that I don’t need to vent the soffits if I have gable vents and ridge vent because the house will be air tight. He was also mentioning over ventilating and possibly doing something with the pressure of the house. Anyway I had planed on using soffit vents as it seemed to be the fail safe way for venting. The house will have an HRV system also.
//m.etiketa4.com/blogs/dept/building-science/lstiburek-s-rules-venting-roofs
Mark,
Building codes require that vented attics have both soffit vents and ridge vents. Most experts advice against gable vents, so you can close those up.
Attic ventilation has nothing to do with HRVs, by the way. Mechanical ventilation for the conditioned space below is an entirely separate topic.
Please be sure that baffles are added between all the rafters and not every third set as I commonly see.
