拙劣的风化改造
迈克尔李|发布了能源效率和耐用性在
我的风化承包商应该遵循BPI(建筑绩效学院)的安装标准。至少,这就是我的合同状态。我在BPI站点状态上找到的标准“在存在拱门通风口,并且可存放是可行的,需要适当的阻挡或挡板,以提供防护保温的风力洗涤。”承包商有问题地安装了2件事。好吧,我猜一个人可能会陷入一点灰色区域,但另一个似乎只是平凡的不正确。首先,承包商在我的屋檐上安装了通风挡板,在那里没有。然而,椽子是16“oc,承包商使用了一半的粉红色筏 - r-mate挡板,这仅是由于它的有效排气宽度小于12”的宽度约3/4的宽度。似乎应该选择更好的装修产品。更重要的是,承包商没有在墙上顶板的挡板周围安装固体空气。相反,承包商在挡板周围安装了未公开的玻璃纤维塞头。 These should keep the cellulose that they blew from going into the soffit. However, I understand that this leaves the area around the eaves subject to the ‘wind washing’ effect and thus a diminished R-value. My question is just how bad might this wind washing affect the efficiency of the insulation? I know this is not a forum for legal advice, but is the problem likely bad enough that I should really insist that the ‘wind washing’ issue be rectified? Can this problem even be reasonably rectified now that there is at least a foot of cellulose blown over the thin batts that were in place prior to the weatherization project? One other related question. The crew installed a couple of inches of thermax over my existing kneewall batts. They did do a nice job with the solid air blocking and foam around the bottom of the vent baffle that goes up the sloped ceiling. However, they used unfaced fiberglass batt plugs around the vent baffle at the top of the slope . The slope contains old fiberglass batts. The top attic contains the old fiberglass with a foot of new cellulose blown on top. Is the lack of air blocking at the top of the slope another big ‘wind washing’ issue? I should note that the vent baffles in the slope were retrofitted, so they are not air sealed to the sheathing along the path of the slope. If it is not already obvious, I have a Cape style house.
  1. 理查德拜托||#1
    在我看来,我建议你拿出空气,现在呼吸真正深呼吸。您可能非常沮丧,您的承包商可能或可能没有安装您预期的系统。我明白这一切。您还必须了解您的合同可能不是您认为的,或者也许是。没有办法读到这一点以知道的人。
    现在您需要退后一步并了解这些公司的大多数并不总是聪明,因为您认为在雇用它们之前。这就是为什么大多数人雇用承包商的基于来自朋友和家人的推荐。有很多公司在那里非常聪明。在现实世界中,一些,不是全部,不能在你家里摆动一把锤子,而不会在一个滑动中突破邻居窗口。
    在你远程考虑在诉讼中挥动挥杆之前了解你的潜水进入一个深深的黑暗道路,这将改变你的生命,可能会清空你的钱包,最后回归。苦涩灌输不会有任何好处。
    尽量保持冷静,并与承包商一起解决。
    解释你的疑虑并向他们展示他们认为他们会与你认为他们所做的事情“平静”来做什么。让他们有机会解决问题。不要离开深渊。你会快速到来。
    如果这不起作用,您可能会发现削减损失(支付他们以避免房地产留置权)的更便宜,然后雇用贸易专家。这一工作阶段并不是昂贵的,以至于开始并且可以固定。感谢您不处理糟糕的喷雾泡沫绝缘工作。
    雇用律师的诉讼应该是你的非常非常良好的手段。
    马丁·霍洛拉||#2
    迈克尔,
    您描述的工作类型是非常常见的,但在至少一个方面,它似乎它似乎不符合BPI标准。
    让您的承包商表示折叠过的BATT不会“阻止,”,但它肯定值得讨论该问题。如果承包商是信誉良好的,并且您向他或她在BPI标准中显示了他或她的语言,您的承包商可能会纠正问题。
    为了我的思维方式,“阻塞”是指刚性泡沫或木材的实心矩形。
