GBA Logo horizontal Facebook LinkedIn Email Pinterest 推特 Instagram YouTube Icon Navigation Search Icon Main Search Icon Video Play Icon Plus Icon Minus Icon Picture icon Hamburger Icon Close Icon Sorted
社区and Q&A
Heat pump COP vs. capacity
Hobbit _|发布了Mechanicals在
虽然回到Marc Rosenbaum提到调整他的热泵,以更加紧密地跟踪加热模式的所需容量,并报告了显着的效率提高。I dug into the documentation for the Daikin here and while it doesn’t really have truly *variable* capacity in heating mode — it tends to just run full-blast because there’s no issue about latent load — it does have a “demand” setting which simply reduces the output to a configurable percentage. This is either a fixed setting or can be externally switched in and out via wired control from, say, a building-management system. The default reduction is to 70% of nominal capacity, so I chose that to play around with. In this case that brings an 18,000 btu/hr down to around a ton, which is approximately the design load for this house anyways.
Last night in our [rather rare!] subzero temps I saw the first
这个系统的实例并不完全跟上负载 -
overnight the house didn’t get above 64F, with a 68F setpoint.
它与除霜的不可避免的暂停连续,
在那些外壳上,有一个轻微的降额曲线,所以我是
guessing that it was doing about 10,000 btu/hr on average.
[I was undoubtedly also getting bit by the “polyiso problem”
*and* heavy night-sky radiation at the same time.]
The problem is that there’s no real way to measure the present
running COP of the system. So here’s the question: how likely
is it that deliberate capacity reduction in a heat pump, in
heating mode, will raise [or lower?] the effective COP? The
major observable change seems to be that the delta between
evaporation and condensation temperatures shrinks a little bit.
Doing my standard meter-read calculations seems to so far return
下降的BTU / HR / DEGF图[这是一个降低的COP 3]
configuration, which might be indicative but there may be a couple
of other factors in play from minor insulation improvements hereabouts.
真的很难告诉这些事情,but if someone can offer
a little theory on whether reduced compressor RPM might affect
performance that’s sort of what I’m fishing for.
_H*
加入建设科学专家的领先社区
  1. Charlie Sullivan||#1
    Reduced compressor RPM can, in theory, help COP because of at least the following:
    1) It reduces the condensor temperature and increases the evaporator temperature, as you mention, thus decreasing the temperature "lift" that it has to work against.
    2)减少与泵送流体周围相关的摩擦损失 - 通常是一个主要因素,但在分裂系统中可能更重要,因为管较长。
    3) If the motor and its control are a modern high performance type, the motor efficiency might go up, particularly if the torque it has to provide is reduced.
  2. John Semmelhack||#2
    Most of the popular mini-split heat pumps out in the market (Mitsubishi, Fujitsu, Daikin, Panasonic, LG, etc.) have fully variable output within their low and high range. For example, the Mitsubishi MUZ/MSZ-FH09 has a published capacity range of 1,600Btu/hr-18,000Btu/hr at 47F outdoors...and it can provide everything in between in very small increments.
    Higher COP at lower compressor speed/frequency is not theory. This is how these units achieve the high performance ratings they get. NREL did some lab testing of a couple of units at many different temperatures, compressor speeds and air handler fan speeds.http://www.nrech.gov/docs/fy11osti/52175.pdf.
    Side note - the COP's for these machines when running at maximum compressor speed are often mediocre at best. It's when they're running at <50% that the "gravy" is made.
  3. Hobbit _||#3
    是的,我读了52175.pdf - 和马尔科的经验......并实现了
    我的系统在加热模式下没有动态自我调整,
    so the only way to approximate that was to set a deliberately
    limited-capacity configuration and see if that could hold up against
    whatever ambient conditions came along. That's caused it to hit a
    limit on those really cold nights, but not in a bad way, and early
    data seems to indicate that it's overall being more efficient so
    I'm probably going to run with this for the rest of the season.
    Daikin可以用一般可配置性做出一个*多*更好的工作
    与这些天空系统的可视性,但至少有
    service and engineering manuals freely online helps quite a bit in
    了解如何工作以及如何调整它们。
    _H*
Recent Questions and Replies
