How to reduce AC noise through a bedroom window?
hello….I live in a groundfloor apt. there are two a/c units right outside my bedroom window, about 2 feet away…my unit and my upstairs neighbors’ unit. i don’t use mine much, but they use theirs ALL THE TIME, even when it’s 65 outside! i really don’t want to move, but i cannot go through another summer of listening to the pervasive deep buzzing sound of their unit. so far, i have tried styrofoam insulation and also sound board, cut to fit into the window on the inside which has a 3 inch sill all around it. have also hung a heavy thick blanket. all of these together cut it about in half, but i can still hear the buzzing throughout my apt. any ideas? i’m just a renter, so i don’t want to replace the window.
there is thick, closed-cell foam available….would this work? i’ve heard the acoustic foam squares would NOT work.
thank you
cindy in reno, NV
Cindy,
Step one is to talk with your landlord. Depending on how loud the noise is, it's possible that there is something wrong with the compressor.
If you have a really nice landlord, it's even possible that he or she might agree to install a new, quieter unit -- especially if the existing unit is old and inefficient.
The standard solution to reducing noise through windows is to install a new window with triple or quadruple glazing and very good weatherstripping. That's not an option in your case.
