GBA Logo horizontal Facebook LinkedIn Email Pinterest 推特 Instagram. YouTube Icon 导航搜索图标 Main Search Icon Video Play Icon Plus Icon Minus Icon Picture icon Hamburger Icon Close Icon Sorted
社区and Q&A
如何将甲板光束固定到混凝土块?
Grey Wolf|发布了General Questions在
iLowes从Lowe购买了这些混凝土甲板块以建造甲板。https://www.lowes.com/pd/Common-7-in-x-11-in-x-11-in-Actual-7-125-in-x-10-375-in-x-10-375-in-Concrete-Deck-Block/50113084
I am putting ~1ft 4x4s on the blocks to raise off the ground.
问题是,块中的空间更多为4“x4”而不是3.5“x 3.5”。此外,块内部并不完全平坦......所以它摇摆不定。
Am I supposed to pour concrete in these first to secure the post, or will it be enough just by the weight of the deck? Do I need a simpson post bracket before placing the beam (I thought the point of these were that post brackets are not needed)?
感谢您的意见。
加入建设科学专家的领先社区
  1. Expert Member
    Malcolm Taylor||#1
    Grey Wolf,
    Unfortunately they are sized for both nominal and actual sized 4"x4"s, which means they can be a bit sloppy. if you want a tight fit you may need to cut some 1/2" pt material and pad out the bottom.
    Remember those blocks are a really just a shortcut to provide some support for a deck. They don't provide any uplift protection of lateral support, and won't meet most codes. If you want any of those attributes you need to form and p0ur the footings yourself.
    More important than a connection to either the block or the beam is some bracing from the post to the structure above to keep the deck from simply toppling over. If it's that close to the ground some diagonal 4"x4"s secured with structural screws will probably suffice.
    1. Grey Wolf||#2
      谢谢(你的)信息!是的,我决定我将在它们的底部放一些液体钉(连接到水泥块)。
      So basically the weight of the deck will hold these down and stable?
      1. Patrick OSullivan||#3
        You're saying beam, but I think you mean post.
        Impossible to say without understand the design of the deck. If the deck is free standing, only having posts on these blocks is likely going to be a pretty shaky structure unless it's cross braced well.
  2. Hammer||#4
    Liquid nails would potentially connect your post to the block better but stability would remain the same. I think it depends on how big your deck is. I would get a lot of concrete blocks and keep them close together. I’m not sure about distance between posts because don’t know how weather in your area is and how big the deck is. Either way having more blocks and posts would make your deck more stable and keep it from moving.
    1. Expert Member
      Malcolm Taylor||#5
      I don't think the spacing or number of blocks will make any difference to how stable the deck is. Only bracing or moment connections between the posts and beams above will do that.
      1. Grey Wolf||#6
        谢谢马尔科姆。你可以更详细地解释一下何时何时可以进入对角线波束?在托梁之前或之后?如果您可以分享图表,那将是很棒的。
        你的意思是这样的:https://www.decks.com/media/4fchyo2n/swaybracing.jpg
        Or like this:https://plasticinehouse.com/wp-content/uploads/2019/08/How-to-Brace-a-Deck-from-Swaying.jpg
        甲板是6x24
        1. Expert Member
          Malcolm Taylor||#8
          Grey Wolf,
          Like the second link. The decking should keep everything fairly square. You just need something to keep it from falling over.
          On decks that close to the ground, I prefer to p0ur a footing with an integral pier up to the bottom of the beams. That deals with both vertical and horizontal loads so no bracing is necessary, and makes the framing a lot easier.
    2. Grey Wolf||#7
      Liquid nails helped with the wiggling. Yea you're right might not do much structurall but helps keep them stable when installing the beams.
      I also used composite shims.
Recent Questions and Replies
