Insulating a 1925 stucco home
I posted a version of this question previously, but it didn’t get as much activity as I was hoping, so I’m trying again. Really hoping for Martin or Dana to weigh in here.
Climate Zone 4 (central VA). House is a 1925 balloon-frame stucco 4-square. There is blocking in the wall stud cavities in between floors. The stud cavities are not open from basement to attic like in some old balloon-frame houses.
Wall assembly is painted stucco on metal mesh>tar paper>1″ x 12″ wood plank sheathing>3.5″ open wall cavity. We have removed all of the old plaster/lath to facilitate electrical, plumbing, and insulation updates. This is a gut/rehab.
So…How should I insulate these walls?
Dense-pack cellulose and rely on its hygroscopic properties (simple)? Treat it like a house with no sheathing and build an air gap, then dense-pack (labor intensive)?
Thanks in advance.
-Travis
Travis,
Is this you under another user name?
//m.etiketa4.com/question/insulating-a-1920-balloon-frame-house-with-stucco-exterior
Nope, that's not me. Very similar circumstances though. The responses there seem to be somewhat contradictory, which is what I've also found while looking through old posts. Hoping to get more a more definitive answer than they did. Maybe wishful thinking.
