旧,漏水的家庭需要新的加热系统
我有一个能源审计预定(尽管现在可能由于现有的现状推出),而随着时间的推移希望升级信封,但最近的油箱检查已经推动了需要将我的加热系统更换为最前沿。
这是信息:佛蒙特州1890年的家,只有很少的信封更新随着时间的推移。2003年的加入搭配BATT,而不是超级安装,绝缘。这是一个双工,已经有多年了,在二楼的租户,我居住在一楼。1425SF足迹。自2013年以来,我已经拥有它。一楼的电流加热是从漏油的油火威廉姆森炉中强制热空气,在无人命的地下室。房屋的其他部分(包括第一楼的一个房间)被丙烷烧制的热水系统加热,以及Rinnai。我有计划将非居住的空间地下室作为未来能源审计后的第一步。油箱泄漏,所以我决定下车并将所有系统转换为丙烷。在现场太阳能不是一个选择。
机械安装者朋友建议了两个不同的系统。1.安装另一个由丙烷发射的Navien锅炉(他最近安装了另一个用于将公寓的热水系统分开,将连接到全面的全面的挡板辐射系统。我会做一堆别针安装和绝缘,以保持低成本。
2.使用现有的导管和炉扇,安装水箱,也可以通过新的Navien锅炉供给。此选项非常便宜(以及我的部件的工作减少)。
I’ve read a bit here and elsewhere on how pin up radiant may be a good option for old, drafty homes. I haven’t heard so much about the hydro coil option and whether that would make more sense. I do plan to upgrade the envelope over time, but it will be a slow process, and won’t happen for a while. I’m a self-employed architect, and finances are an issue, but I want to keep energy efficiency in mind as I upgrade, so I’m willing to pay a bit more for a more efficient system…of course, understanding that I do need to get some of the worst case drafty areas fixed asap. One concern I have is with the constant energy needed for the circulator in a pin up install, but maybe I’m not seeing the forest for the trees. Any input would be appreciated.
GBA详细资料库
由气候和房屋部件组织的一千个建筑细节的集合
RE:从石油转换为丙烷:每加仑,燃烧油比丙烷(135,000 vs.93,000)产生约40%的人。在缅因州,一加仑的石油价格与一加仑丙烷大致相同。
Prices look to be close to each other in VT as well but as you pointed out you get substantially more btus from oil.
https://publicservice.vermont.gov/content/retail-prices-heating-fuels.
$3/gallon propane works out clost to $0.10/kWh electric equivalent.
If your electricity cost is near that, heating with resistance heaters would be similar cost but MUCH cheaper install.
Your lower operating cost option is to replace the existing air handler with a heat pump.
Something like a Mitsubish SVZ-KP18NA mated to a MXZ-3C24NA2 with a wall mount head in the basement for heat, should get you much lower operating cost and for a slightly more expensive install.
确保对空间的绝缘绝缘升级进行热负荷计算,对于这些多拆分,您需要将它们与其紧密匹配,否则效率会受到影响。我的感觉是MXZ-3C24NA2已经过时了。
如果您有冬季时间填写数据,可以通过以下步骤查看现有的热量负载:
https://www.greenbuildingadadadyor.com/article/out-with-the-old-in-with-the- new.
您不需要等待能源审计知道您需要空气密封并使地下室隔热。如果您还没有,请阅读文章,并开始接受该任务。至少开始设计,规范和寻找承包商部分的过程,以便您已准备好。如果您在此处做得好,您可以在加热负载(和成本)上节省15%或更多。
