Please compare and contrast the benefits of open cell insulation compared to spray foam insulation in regards to window installa
Bradley Williamson| Posted inEnergy Efficiency and Durabilityon
I want to learn about the pros and cons of using open cell insulation and closed cell spray foam insulation in regards to window installation.
Usually spray foam insulation is not used directly up against windows, either open or closed cell. Exceptions would be a fixed, not moving parts window, where the gap between the rough opening framing and the window frame is large.
A specific foam to seal around doors and windows is a single component foam designed to be low expansion and easily dispensed from a can. I use Hilti door and window foam. Other brands are Dap, Great Stuff, and many others.
Open cell is a form of polyurethane spray foam insulation that is installed at a typical density of 0.5 pcf, and closed cell is another form of polyurethane spray foam insulation that is installed at a typical density of 2.0 pcf. Open cell has a typical R-value of 3.4/inch while closed cell is typically 6.5/inch. Open cell is somewhat vapor open while closed cell is a vapor barrier.
They are used only for insulating large volume areas, not window openings.
