Recessed slab question: How to pour?
I am building a small 12′ x 16′ shop that will be plumbed with a wet room. The foundation will be a slab on grade with a recessed slab for the wet room. In order to achieve the recess in the slab (probably ~3″), I am wondering if it makes more sense to do 2 separate pours and/or use an expansion joint in the slab to control cracking and thermal changes. I have attached a rough rendering of what I envision the slab to look like. I’m just not sure how to best approach this recessed slab.
John,
My guess is that you will want to pour everything at once, with a curb form at the transition. But the person you need to ask is your concrete contractor.
