Roof venting question
Martin:
我住在5区,预计很快就会建造。在制定新代码之前,我于2009年12月获得了建筑许可证。
My architect and I submitted plans for a 1,700 sq. ft. footprint, with the basic, called for insulation to code in the drawings. And now we hope to show 4″ rigid on the walls and I thought 2″ rigid on the roof sheathing, and possibly R-30 or R-38 tacked between the rafters or trusses would do.
But the architect is not sure it will meet code, because the walls are 26′ apart and either system would most likely require collar ties, in which case there would be SPACE between the batts and the roof/rigid, and it would need to be vented to code, correct?
这种与我紧张的信封计划背道而驰……他建议我与您联系。马丁,我们在这里错过了什么?
Steve B.
GBA细节库
由气候和房屋部分组织的一千个建筑细节的集合
史蒂文,
我不确定我是否正确理解您的问题,但是我会努力解释它。我认为您在问在屋顶护套下面有通风槽,after子之间的玻璃纤维板和固定的泡沫是否有意义。
如果这是您的问题,答案是否定的。如果您在玻璃纤维板和屋顶护套之间安装通风沟,则在屋顶护套的顶部安装刚性泡沫是没有意义的。
如果我猜到您的问题是错误的,请改写您的问题。
Martin:
真的很抱歉,这不是正确的。我的最初计划是建立仅在Advantech护套屋顶上使用刚性的信封,但使用6多英寸刚性(固定)的储备。显然需要使用NYS代码和独立乡镇执法妥协。我可以在屋顶上使用什么隔热系统,使我大教堂或改良的大教堂,就此而言,使用2倍木材或桁架的房屋的其余部分带有平坦的天花板?该计划是R-26刚性墙(2x4墙壁可将窗户盒保持在最低限度)。为Huber射击的墙壁射击,并希望获得最小的空气变化,并仅使用风扇(Braun)通风。有一个简单的屋顶绝缘吗?与城镇/州以及我的能源期望的系统?
史蒂文,
这是一个非常广泛的问题,当然有很多答案。对于绝缘的倾斜(大教堂)天花板,您可以使用以下任何内容:
1.屋顶护套上方的厚泡沫。
2. sip
3.钉子在屋顶护套的顶部。
4.在屋顶护套上方的泡沫和腔室中的腔体隔热(无通风)的组合。
5.在a子之间喷涂泡沫绝缘。
6.通风槽下的密集包装纤维素。
...这只是一个抽样。有很多构建方法!
For an insulated flat ceiling, you can use:
1.厚纤维素
2. Thick blown-in fiberglass
3.喷雾泡沫绝缘
...以及许多其他类型的绝缘材料。
你能缩小问题吗?
Boy! Let me try to better explain.....Whether i use rafters with a collar tie,OR trusses with a bottom plate that is lower that collar tie, I still have an air space somewhere with un-conditioned space that architect says needs to be vented to code. I'm thinking that whatever insulation system used,IF it is applied ABOVE air space, such as rigid on sheathing, with possible 1-2" flash under sheathing, then I would be fine, code wise, to not require venting,which I DO NOT WANT!!I realize there is some heat loss from below modified cathedral, thru drywall, to un-cond. space, but with a hopeful 1-2 Ach/hr home, I should be good. Does this game plan meet with building code specs in your opinion?
史蒂文,
我认为您的建筑师是正确的,如果有一个未通风的组件,上面有刚性的隔热材料,那么在底面和任何其他腔体绝缘之间,不应有任何空间空间。如果您不认为没有这个不需要的空间空间就可以安装腔隔离,那么您的替代方案是(1)刚性隔热材料,如您所说,较长的紧固件,或(2)腔隔热,并以排气为代码要求。
借助后者,您需要特别注意将天花板上的石膏板密封,以实现您的空气紧密度。在安装绝缘材料之前,避免点灯并仔细密封所有渗透。
史蒂文,
Your writing is unclear, and I have no idea what you are talking about. Let's start at the beginning.
1. Question one: are you talking about a cold, unconditioned attic or an insulated sloping roof?
2. Question two: do you prefer a ventilation gap or do you prefer an unventilated ("hot") roof?
(1)绝缘倾斜屋顶
(2)更喜欢无泄漏的(热)屋顶
Steve,
在大多数建筑法规中都允许绝缘的热屋顶。例如,在2009年IRC中,可以在R806.4节中找到要求。
谢谢马丁!
