Siding materials
seb75| Posted inGreen Products and Materialson
which siding materials are efficient, and ecoomic
without off gassing
Seb75,
1. Builders don't depend on siding for "efficiency." (I assume that you are probably talking about energy efficiency.) Energy efficiency is improved when a wall is relatively airtight and has a high R-value. Siding is installed after airtightness work is complete and after insulation has been installed.
2. Probably the "most economic" (cheapest) sidings are T-111 or vinyl siding.
3. There are no off-gassing concerns with siding. Siding is installed outdoors, outside of the home's air barrier.
