Taping Bottom Seams of Exterior Foam Insulation
Hi,
I understand the seams of the insulation boards need to be taped. I already have the bottom seams of the OSB sheathing taped with the concrete of the foundation. Do I have to tape the bottom seams of the insulation boards to the concrete? I think the answer is yes, as we want to reduce air leak.
I have seen people using regular vapour barrier tape… My plan is to use the Siga wigluv tape for that, as it is exterior/rain rated and…I am building a rain screen… Am I overdoing it?
Bonai,
- Are you using the insulation as your WRB?
- What is your primary air-barrier?
Blueskin VP 100 is the primary WRB.
Im quite confident both type of tape will initially stick on the foam boards, especially that they are covered with a poly film. But overtime, the normal vapour tape is not exterior/rain rated... Thats why I am thibking to spend more and go with the Siga tape.
