Anyone have 2” Rockwool comfortboard?
Building a house in Northern WI.
I have 3/4 of my needed 2” Rockwool Comfortboard, however, I can’t find any additional anywhere. Every where is out until Rockwool supplies more in November.
anyone have any within a driveable distance of MN or WI? I need about 1000 square feet.
You can also try searching for OC Thermafiber, seems to be more readily available around me. They have a number of different semi rigid panels that can work.
My local Grainger (SE Michigan) carries 2” 8 lb Roxul (old name for rockwool) in 2 ft x 4 ft sheets. This is aimed at the industrial insulation market, but I would assume it would be very similar if not exactly comfortboard 80. Online price shows $2.27 per sqft.
