GBA标志有何利zontal Facebook LinkedIn 电子邮件 Pinterest Twitter Instagram YouTube图标 Navigation Search Icon 主搜索图标 视频播放图标 加上图标 减号图标 图标图标 汉堡图标 关闭图标 分类
Attic insulation project
John McNamara|Posted in一般的问题on
This email touches on a few topics covered often on the podcast and in the magazine.
完成独立的能源审核之后,我进行了一些更轻松的建议改进。5月,我们正在完成以下工作:1。去除旧的绝缘/碎屑,2。K&T恢复,&3。空气密封(指示打击器门),然后4。爆炸的纤维素。
(阁楼清洁日和新的绝缘材料之间将有14天的窗口。在此间隔中,阁楼的剩余K&T被断开并删除。)
The plan had seemed straight-forward. I picked this company due to its emphasis on building science’s best practices, but now I realize I’ve still got questions & concerns:
首先:绝缘项目经理认为,拱腹通风口可能没有功能,即没有连接到阁楼上,只是“表演”。他说他一直都在看到。他的建议是在屋顶的后朝南侧安装2个下部的2个进气口,以提供源空气如果这soffits are, in fact, non-functional (the ridge vent是功能性和相反的山墙通风口。)
第二:从阁楼上的对角线上(在东西侧和西侧;东侧;在附件图像中的左侧)在“挤压壁橱”*周围*然后进入门廊天花板上。这些壁橱和墙壁在冬天变得寒冷。绝缘子的计划是将纤维素吹到空隙/通道上,足以覆盖壁橱的顶部。我想知道这将有多有效。我认为我应该打开门廊天花板,并用泡沫板(Cut-n-Cobble)和填缝枪从下面攻击它。
[*Squeeze closets are 14″ deep & extend apprx 3′ to one side & 1′ to the other.]
[Note: In the image provided:
这黄色代表阁楼的地板和从屋顶下方的阁楼下方,然后进入门廊天花板的连接;
这粉色的区域是在门廊天花板和主卧室的地板之间安装XPS和玻璃纤维板条的绝缘三明治(无地板);粉红色的问号是我担心的区域没有很好地绝缘。
和green盒子是卧室两侧的两个挤压壁橱之一。]
我会感谢任何想法。我在这里有些思考吗?
    Akos||#1
    With this type of work, the most important thing to get right is air sealing. Since lot of the spaces are awkward, the best is either spray foam or dense pack.
    对于您的挤压壁橱区域,这将阻止屋顶通道通道,在大多数情况下,只要上面的阁楼空间被排出。您的安装程序可以用标准的纤维素机器获得一个半密集的包装,其还原器为1.5“软管。
    Typically the floor overhangs above a porch are only 2x6. No matter what you put in there, it won't be a lot of R value, it will be better but it will still be cold. To properly fix problem, you need to pull the porch ceiling and insulate with a thick sheet of continuous rigid insulation under the joists.
  2. Walter Ahlgrim||#2
    There are few times when I recommend spray foam and a conditioned attic but retrofitting a story and a half building is when the risk and high cost of spray foam is worth it in my mind.
    在没有喷雾泡沫的情况下,天花板和楼上地板之间的温暖空气将通过膝盖墙和阁楼通风口找到出口。从理论上讲,承包商可以将XPS紧紧地安装到以阻止空气流量的情况下,但是泄漏使工人处于紧张的痛苦地点,事实证明,单独的钱是足以使人们在这种情况下做到完美工作的人。
    在工作开始之前,请确保您的出价包含A,并在工作完成后完成鼓风机门号。
    沃尔塔
  3. John McNamara||#3
    沃尔特 - 但我没有膝盖墙。这会改变您的分析吗?
    Akos-我将向项目经理发送有关紧密软管的电子邮件,这听起来很有希望。
    至于门廊,我在想,因为我正在放一个新的天花板(现在只是涂上OSB),以便在天气改善时打开和评估“三明治”。当时,我将使用这种情况的照片更新此线程。
    Thanks
登录或创建一个帐户以发布答案。
Community
最近的问题和答复
