Best glazing option
我建立一个greenhouse that will track the sun in Vermont. Glazed on the one side that faces the sun. It will have an R20 insulated door that will cover all glass at night
What is the best glazing option for balance of heat gain/loss on cloudy days ?
Will south facing single pane glass loose heat on cloudy days?
Thanks for any thoughts,Kurt
Kurt,
The easiest question to answer is the last one:
Q. "Will south facing single pane glass loose heat on cloudy days?"
A. Yes, unless you limit your definition of "days" to mean "the part of the day between 10:00 am and 2:00 pm" and unless you limit your definition of "cloudy" to mean "with only a very thin layer of translucent clouds."
Q. "What is the best glazing option for balance of heat gain/loss on cloudy days?"
A. There is no easy answer to your question. You will need to compromise. Glass with a low U-factor (for example, triple glazing with two low-e coatings and argon gas fill) will have less heat loss on cloudy days, but most types of low-U-factor glass also have a lower SHGC. High-SHGC glass (a single layer of low-iron glass) has a high U-factor. There is no magic glass with a very high SHGC and a very low U-factor.
For more information on this issue, see关于玻璃的所有选择.
Thanks for the quick reply Martin,
Since It will need light for the plants and heat for the fish I'm probably better off with 2 or 3 layers.
Any suggestions for sourcing glass units in the 6'to 6-6 tall range?
再次感谢,库尔特
Kurt,
Back in the 1970s, we were all using IGUs sold as "patio door replacement glass" -- the size was standardized and the price was cheap -- to build passive solar homes and greenhouses. You could ask local glass suppliers if they have any low-cost units.
Kurt,
I used to buy these IGUs in boxes of 10 -- they came in a wooden crate. I still have a few in my basement -- just went down to measure them. They are 34"x76".
我会说“让我要约”,但我真的不认为你想要它们。
Kurt: If you plan on building a greenhouse from scratch, I'd look into polycarbonate panels.
Thanks guys,
I will look into those options .
Martin how many do you have? Are they 70s vintage?location? I'm near Burlington,VT.
Stephen what is the life cycle of the pc. Insulated panels
Kurt
Kurt,
我的igus不出售。他们已经存储了40年,您不想要它们。最近制作产品 - 理想情况下,一些具有低涂层和氩气填充物的Igus。
库尔特:我不知道聚碳酸酯面板持续了多长时间,但是它们比绝缘玻璃便宜得多。由于它们也更轻,因此建造温室应该更容易。我会去当地的商业温室,看看专业人士对聚碳酸酯的看法。面板有各种尺寸和厚度。
非常感谢Martin&Stephen的建议。
Best, Kurt
