我可以在嵌入式壁橱里做CFL嵌入式照明吗?
我们正在进行一个项目,客户希望在步入式壁橱里凹陷照明。电气密码要求壁橱中的照明为低热量氟叉架(以防止在储存过多的存储区域发生火灾)。而且没有良好的荧光特异性重新发明的灯光。
We proposed to do a CFL bulb in a traditional recessed housing, and the cheif and field electrical inspector can’t decide if this is kosher.
是:CFL灯泡满足NEC 410.16的SPIRT和技术要求
NO: There is no way to know what a furture owner will replace the bulb with, and therefore a dedicated florescent fixture is the only way to meet the code
Does anyone have any expereince with such installations?
Thanks,
亚伦
GBA细节库
只需购买基于PIN的CFL,它将被证明
I bought some at the big box store...not to expensive.
我的检查员对这个概念很好。
Also if you are doing Energy Star .. you will get more brownie points.
哦,你说凹陷..从不头脑
John -
什么是基于PIN的CFL?
Thanks
亚伦
亚伦,我知道它们(销底座)在加利福尼亚很常见(也许是强制性)。
销底座是推入类型的连接,而不是更常见的螺丝底座。
我认为可以特别订购嵌入式罐子。
Interesting. I couldn't find any recessed fixtures with the pin mounting. Makes sense. Do you know of any suppliers?
有趣的是。。。。我无法将任何带有快速的Google凹陷的别针底座。...如果有人拥有它是加利福尼亚。.我认为他们称法律为法律(螺钉基础的非法)T24。
还有其他可供凹入式固定装置的缺点。.我知道还有一些(销底座CFL)吸引人的表面固定灯..(Kischler,一个)
The bi-pin base is properly called a GU24 base.
没有理由您不能使用嵌入式固定装置(GU24),尽管它们可能不是壁橱的最佳照明。
取决于壁橱是典型的24英寸深壁橱还是步入式壁橱。
A 24" deep closet is better lighted with surface-mounted fluorescent strip lighting mounted horizontally above the door(s), because a light in or on the ceiling will be blocked by the hanging clothes. Fluorescent under-cabinet lights are ideal for this purpose as they are directional. There are even some specific closet lights available that are a part of the clothes rod.
A walk-in closet could have recessed fixtures if the client prefers them. A better approach is sconces for ambient light (if you have some wall space) and directional (eyeball) fixtures pointing on the clothing.
Also important is your choice of lamping for the fixtures (if you want to be able to discern black from navy blue).
尝试在85-95 CRI范围(越高)中找到荧光灯(灯泡),以使颜色渲染良好。这些灯通常在商店中不可用。在线搜索它们,仅从信誉良好的来源(例如GE,Philips和Bulbs.com)购买。
我相信还有另一个可行的选择,亚伦,可以为您提供所需的一切。
我把嵌入可以在(不少o LEDf) closets in a San Francisco remodel my firm designed. They were CREE LR4E's, and besides being substantially more energy-efficient than CFL's, they give off practically no heat, so combustion became a non-issue.
它们并不便宜,但它们适合账单,灯光为2700K,可选择15或30度。
也就是说,佩吉在壁橱照明功能上的评论已被备受胜利。我们关注的一部分是点燃壁橱,部分是从后面照亮壁橱门的半透明面板(用于大厅的重音照明)。因此,该解决方案为我们完成了。但可能不是每种情况下最好的解决方案...
大家好,谢谢您的所有信息!顺便说一下,您喜欢哪种品牌的嵌入光灯?您知道我不是在设计时,我只需要可以随时轻松安装和更换灯泡的东西。如果可能的话,一个便宜的。我试图浏览这个网站http://sararte.com/, and they have like thousands designs, and I have no idea on it. I am a newbie when it comes to things like that. Help please, anyone? Thanks a lot!
"They were CREE LR4E's, and besides being substantially more energy-efficient than CFL's, they give off practically no heat, so combustion became a non-issue."
只是注意的注意事项:大多数生产LED都不比CFL更节能,而且许多LED效率较低。例外是定向应用,其中LED的Excel和CFL没有。另外,某些LED固定装置也存在重大的热问题 - 即使在需要连续的风扇冷却的程度上也是如此。
CREE LR4E的运行约46个流明/瓦,与平均CFL相同。但是,与表面安装的等效功率输入相比,光线也会将大部分光线投放在地板上,几乎肯定会效果不佳。如果安装到阁楼区域,可以允许灯从条件空间泄漏的灯也可以臭名昭著。当然,如果您的优先级是美学效果而不是环境绩效,那么这些特征可能不会关注。
