GBA标志水平 Facebook LinkedIn 电子邮件 Pinterest 推特 Instagram. YouTube Icon 导航搜索图标 Main Search Icon Video Play Icon 加图标 Minus Icon Picture icon Hamburger Icon 关闭图标 Sorted
社区and Q&A
不能说服邻居不使用玻璃纤维,所以什么是最好的糟糕选择?
乔治·努力|发布了能源效率和耐用性在
有一个问题在绝缘,actually trying to guide a neighbor who is also finishing basement and we are buying items together to get some discounted prices.
What we differ on is reason for basement; we are doing for personal use and he is doing for sale of house in spring/summer. Hence while I have decided on xps for wall insulation he has decided [for cost savings] to leave existing blanket pink fiberglass insulation then to frame in front and then new pink fiberglass batts.
I initially tried to discourage with no luck so now trying to make best of it. Did suggest not to have double vapor barrier and therefore he should slit or remove the existing VB once framing done and then VB over new batts.
But then read online how it is advised that fiberglass insulation not to touch cement walls.
我向邻居建议是错误的吗?
将现有的毯子粉红色玻璃纤维绝缘留在VB [无狭缝而不是删除]然后在前面的框架上框架,并将新的玻璃纤维BATT放入没有VB的情况下,然后干燥墙?
我的推理,请建议如果有意义,那是现有的绝缘是最小的,而关于双重的新击球率使新的击球仪靠在旧隔热的塑料VB上,然后抵靠水泥墙壁;希望减少水分/模具的机会。还是我完全不合逻辑?
谢谢!!
加入建设科学专家的领先社区
  1. GBA Editor
    乔治,
    我认为你的邻居犯了一个错误。这种组件中的任何聚乙烯层(我假设我们正在谈论安装在地下室墙壁的内侧上的绝缘)可以捕获水分。水分可以来自组装的混凝土侧,水分可以来自内部(作为可以在冷聚乙烯上冷凝的水蒸气)。根据季节和温度曲线,如果邻居在该壁组件中包括聚乙烯,则可能导致水分积累。
    My advice is simple: remove all of the existing fiberglass batts and the existing polyethylene and put the materials in a Dumpster. If your neighbor wants to insulate basement walls on the interior, he should use rigid foam or closed-cell spray foam.
    以下是有关此问题的更多信息的文章的链接:How to Insulate a Basement Wall.
  2. Jim Tyler||#2
    你们有人看过刚性的刚性保温吗?也许使用回收的泡沫的成本节约将有助于让邻居在正确的轨道上。
  3. dorsett.||#3
    XPS among the least-green foam insulation choices due to the HFC134a blowing agent used. EPS or polyiso are blown with pentane, which is far more benign. (Less than 1% of the global warming potential of HFC134a, and in many or most cases the bulk of that pentane is recovered and burned for process heat at he manufacturing site, turning it into CO2 and water, which are even more benign.)
    在没有洪水历史的合理干燥地下室,合理地使用刚性泡沫与混凝土的组合,用玻璃纤维或岩棉羊毛绝缘壁到刚性泡沫的内侧。必须在没有内侧蒸汽屏障的情况下进行,以避免刚刚夹持的水分 - 仅脱气或牛皮纸面对纤维绝缘,而且没有聚乙烯片,乙烯基或箔壁纸,只有标准的乳胶涂料。如果板坯没有从下方绝缘,则建议底板和板之间的一英寸的EPS作为毛细管和热断裂。
    The amount of wall foam necessary to make this a moisture safe assembly depend on climate. If you used the IRC chapter 7 prescriptives for wood-sheathed above grade walls for your climate zone, it would be sufficient for basement walls as well.
    http://publicecodes.cyberregs.com/icod/irc/2012/icod_irc_2012_7_sec002_par025.htm
    In most of the northern US climate zones code-min for basement walls would be the equivalent of R15 continuous insulation. That could be 3" of polyiso, 4" of EPS. In zone 5 that could be either 1" of polyiso or 1.5" of EPS and a 2x4 studwall with R13-R15 batts, but in higher zones it would require a bit more foam (and it would beat code-min performance). In zone 6 that could be 1.5" polyiso or 2" of EPS, in zones 7 & 8 it could be done with 1.5" of polyiso or 2" of EPS, plus a 2x3 studwall and compressed batts.
    http:///publicecodes.Cyber​​Regs.com/ICOD/IRC/2012/ICOD_IRC_2012_11_SEC002.HTM.
  4. 乔治·努力||#4
    Hi Martin, Totally agree with your suggestion however neighbor not going to stay at house for long time before selling so can not convince otherwise.
    For my part, happy to see that local hardware store has xps on sale.
    回到邻居,因为不能改变主意,是有较小的邪恶:
    *留下现有的VB然后框架然后击打然后干墙?
    *删除现有的VB然后击球然后VB然后是干墙?
    谢谢。
    P.S.你的方法是如何使托泰斯的绝缘非常好,即将完成今天!
  5. 艾伦B.||#5
    Where are you located OP?
  6. GBA Editor
    马丁·霍洛拉||#6
    乔治,
    我试图为邻居提供有用的建议。我真的希望你的邻居好运。
    聚乙烯和玻璃纤维毡不适合绝缘地壁的内部。如果你的邻居从头开始,那真的是最好的。
  7. Expert Member
    Dana Dorsett||#7
    George: Polyethylene clad batting of the type used in metal buildings had a brief surge in popularity as basement insulation a couple of decades ago, but it's track record over the long haul has been generally poor, with lots of failures and unintended mold-farms. Covering it up with new fiber insulation won't fix anything, it will only make it worse.
    You still haven't hinted about your climate zone / location and it might actually matter, changing the particulars of what works or doesn't.
