大教堂天花板阁楼绝缘与臀部和山谷
德鲁特T.|发布了一般的问题在
我在堪萨斯城(6区)有一个100岁的石头家。与KC中的大多数家庭不同,我的房子是在一个平板上建造的,我的HVAC空气处理器和在阁楼里管道。I’ve been searching the forums for a few years looking for advice on how best to move from an insulated floor in my attic to an insulated ceiling to create an 800 sqft section of the attic where my HVAC mechanicals reside as well as create some storage space. For several reasons I had to tackle the project earlier than anticipated (35 yr old air handler went out > wouldn’t fit through the attic access door > had to cut new access door > vermiculite insulation > asbestos remediation > zero insulation in the center of my attic). I started moving forward with the advice I found on this post here://m.etiketa4.com/question/rigid-foam-attached-to-underside-of-rafters-good-dea
我开始在椽子腔内安装高密度R-15 Batt(2 x 6椽子,留下2“空气流动的间隙),并有2”面向箔面的Polyiso泡沫板,我将在椽子上胶水,胶带接缝,螺丝1“毛皮条带到椽子上握住它们。
这很简单......除了我阁楼的臀部和山谷部分。看起来我在这里有一些选择:
1.安装某种类似的臀部通风口:
https://www.gaf.com/en-us/products/cobra-hepvent.(安装说明说要仅在臀部的50%上安装这些,所以这不会解决我的通风问题,以便降低50%的臀部)
2.使用一些创意框架允许臀部和谷椽下的气流(如果我的阁楼楼梯没有那么接近臀部屋顶,这将是一个相当简单的解决方案。看图片。)
3.在椽子中钻孔,祈求一些十字气流(我不能将我的头缠绕在这将如何工作,而且我不喜欢用屋顶的结构完整性弄乱的想法)
4.闭孔喷雾泡沫
是否有可能/建议将封闭式电池喷雾泡沫结合在臀部屋顶椽子和R-15和Polyiso泡沫选项中,在那里我可以实现覆盖脊通气的剖腹产?
加入建设科学专家的领先社区
