外部矿物木板没有屋顶
吉姆·赫德|发布能源效率和耐用性上
40岁以上的房屋,SE PA,2×4,带有玻璃纤维绝缘。灰泥在这里很糟糕,因此更改为硬皮单。我们正在穿上新的屋顶,摆脱天窗并安装太阳能。这是一个山墙的屋顶,冷屋顶,吹牛 +玻璃纤维。阁楼没有管道工作。它具有山脊通风口 +拱腹通风口 +山墙端通风口。我们有一个5吨热泵。
It would be nice to go around with comfort board since the insulation is so obsolete and not very well sealed but the overhangs are not much (basically non-existent on the gable ends) so we’d have to build the roof out longer to cover it and I have trouble finding contractors that want to do anything even a little out of normal here. How worthwhile is this, and how hard is it for a contractor? Are there things I should consider instead?
登录或创建一个帐户以发布答案。
最近的问题和答复
