闪烁的胶带在毡纸上
SSBDAMION|发布一般的问题上
大家好,我有一个奇怪的情况。我的房子是一栋70年代的房子,外墙由一层毛毡纸和灰泥组成。There is no sheathing and the house in in Southern California climate zone 3. I had a shower redone and noticed after demo that the south facing felt paper wasn’t in great shape, but there were no signs of constant leaking, and if there was, it dried since it doesn’t rain much here. My contractor said he would do something about it before the shower was redone. I didn’t think much of it, but looking back I realize that he used flashing tape to cover the felt paper. This seems odd since there is now a vapor barrier on the felt paper and I’m looking for advice on how much of an issue this may cause. Replacing the stucco from the outside will be a major project since the stucco is considered the shear wall and all the demo will likely ruin the waterproofing of the new shower that is now installed. The shower walls were waterproofed using felt paper and floating the walls, which is fairly standard in Southern California. I’ve attached photos and looking for advice on how serious of an issue this may be and if/how I should act to fix it?
  1. 用户2310254||#1
    我无法从您的照片中弄清楚品牌,但我不确定这是一件大事(专家可能不同意)。例如,ZIP胶带的额定值为3个PERM,您的胶带可能具有类似的渗透率额定值。
    FWIW,我更担心将散装水从墙壁腔内放在。如果您的承包商将水泥板与Schluter或Redguard之类的东西结合使用,那么您可能很好。
    我唯一要看的是浴室通风。您真的想要一个高质量的粉丝(Panasonic Whisper风扇很棒),并有足够的CFM将水分排在户外。如果您有避免打开粉丝的家庭成员,我将安装带有自动计时器的运动传感器,以避免长期问题。
  2. SSBDAMION||#2
    史蒂夫,谢谢您的答复。闪烁的胶带是fortiflash,根据规格表,其倍数额定值小于0.1。关于浴室风扇,尚未安装,但它将是一种松下,烤面包或幻想,它将耗尽屋顶,我将安装一个计时器或传感器。
登录或创建一个帐户以发布答案。
最近的问题和答复
